Zam Posted October 21, 2015 Report Posted October 21, 2015 HiMy question is very simple, I read about MBHP_ETH but It's not clear to me if I can connect both SDcard and ETH at J16 ?!?I'm using STM32F4 core, and I want to try OSC for my system.I'm planing to do it in protoboard, but maybe there is some interest if I take the PCB (with kicad) route ?For info the controller seems available again in DIL package at reichelt.BestZam Quote
latigid on Posted October 22, 2015 Report Posted October 22, 2015 For the older 32 bit Cores, yes you can chain an ETH and SD off the same cable because they are pinned to accept different RC lines if I recall properly. For the F4 Core, you have SD on board, so why the need for another? Quote
Zam Posted October 22, 2015 Author Report Posted October 22, 2015 HiWithout proper socket my SD card is connected at J16 with ribbon and direct solder to SDhoder for miniSD card, but that' not the point :)Anyway I just find the info at J16 description for STM32 (miss that...)Note: the MBHP_CORE_STM32F4 module has an on-board SD Card Socket, which is directly connected to J16!so I check again SD card page and ETH page.SD use RC1 and ETH use RC2Now whole J16 connection make sense to me :)BestZam Quote
Zam Posted December 10, 2015 Author Report Posted December 10, 2015 Hi allNow it's time to test OSC for my project !I have all part to do an ETH module, I just have some question regarding component placement/layout.C7, as close as possible to pin 28 ? in fact close // with C9 ?C6, as close as possible to pin 19-20 ?http://ucapps.de/mbhp/mbhp_eth_v2.pdfBestZam Quote
latigid on Posted December 10, 2015 Report Posted December 10, 2015 The original layout from seppoman Quote
TK. Posted December 10, 2015 Report Posted December 10, 2015 C7 close to pin 28C6 close to pin 19 and 20Best Regards, Thorsten. Quote
Zam Posted December 10, 2015 Author Report Posted December 10, 2015 Hi TKtks for confirmation.BestZam Quote
