eptheca Posted November 17, 2015 Report Posted November 17, 2015 Hi,I have changed the order of these in the DIN/DOUT chain.I now have the TPD first then the BLMI have edited the MBSEQ_HW file, but there is something wrong.The 4 LED's on the TPD are constantly on, and the BLM acts strangeCould someone please check the attached file, and see if they can see something wrongCheers:) MBSEQ_HW.V4 Quote
electrodancer Posted November 20, 2015 Report Posted November 20, 2015 i would also like this set up...please let me know if you get this sorted Quote
TK. Posted November 22, 2015 Report Posted November 22, 2015 At a first glance I don't see a configuration error.However, I think that this combination can lead to unstable SRIO transfers because of the high number of SRIOs and different chain lengths of the DIN/DOUT SRs. This would also explain, why the BLM acts strange.A prober solution to overcome this problem is MBHP_LINE_DRIVER: http://www.ucapps.de/mbhp_line_driver.htmlI don't know how exactly your hardware looks like, but if the TPD is close to the wilba frontpanel, then it's sufficient to connect the transmitter/receiver between TPD and BLM4x16Best Regards, Thorsten. Quote
eptheca Posted November 22, 2015 Author Report Posted November 22, 2015 Thanks for the tip TK.I don't understand the behavior because I have used it for a while with the TPD connected after the BLM, and it's worked fine.The only reason I changed it was because I saw that I could get a shorter cable if I connected them in the reverse order.My hardware looks like thisOn Wilba's frontpanel the DIN/DOUT connectors are on the left side.On the TPD they are next to each other, but on the BLM the IN is on the left side and the OUT is on the right.It made sense to me to keep the cable stretches as short as possible, so I tried Core -> Frontpanel -> TPD -> BLM with the attached config file, but I ran in to the problems mentioned.I guess I should follow the "If it ain't broke, don't fix it" rule.I'll just revert back, shut up and make some music ;) Quote
electrodancer Posted November 23, 2015 Report Posted November 23, 2015 i have tried this with the Line Driver Transmitter/Receiver...(because i wanted more distance between Sequencer and BLM/TPD.But in my case it did not work.....with the linedrivers the buttons/leds were acting strange....and when i removed the linedrivers and connected it with flatcable...it worked okay....(i know the linedrivers are also okay as ive also used them with the Aout-NG without any problems) Quote
electrodancer Posted November 23, 2015 Report Posted November 23, 2015 maybe a ferrite can help to solve this problem ?http://www.reichelt.nl/FERRIT-FB-10/3/index.html?&ACTION=3&LA=446&ARTICLE=7665&artnr=FERRIT+FB-10&SEARCH=ferrite Quote
TK. Posted November 23, 2015 Report Posted November 23, 2015 No, it won't help.The problem is, that the TPD has many DOUT shift registers, but only a single DIN shift register (as far as I remember). This results into an unbalanced serial output which leads to trouble when another module with DIN/DOUT registers (such as the BLM16x4) is connected.So - this kind of module will only work at the end of a serial chain, or with some buffering (and some luck) - it's a complex topic, I can't give you a fool-proven solution without further analysis (and I won't have the time for this anyhow... ;-)Best Regards, Thorsten. Quote
ilmenator Posted November 24, 2015 Report Posted November 24, 2015 The problem is, that the TPD has many DOUT shift registers, but only a single DIN shift register (as far as I remember). This results into an unbalanced serial output which leads to trouble when another module with DIN/DOUT registers (such as the BLM16x4) is connected.That is right, there are 9 DOUT shift registers but only 1 DIN. It seems best to simply leave the TPD at the end of the chain and ignore the OUT port then. Quote
eptheca Posted November 24, 2015 Author Report Posted November 24, 2015 OK. I have reverted back, and it works fine like before.I wanted to add some gate triggers, so I guess I have to add them before the TPD then, or can anyone suggest an easier/better way to add 8 gate triggers? Quote
ilmenator Posted November 24, 2015 Report Posted November 24, 2015 As the gate triggers are not arranged in a matrix configuration it should not matter where in the chain they are located. I guess the critical timing issues only arise when matrixing ins/outs. For these (like the BLM), an equal number of DIN and DOUT SRs should precede in the chain to keep the timing undistorted. Quote
