fcebreros
Remote BPM?
9 posts in this topic
Is there a way to change the BPM  (fire a BPM preset) with a  MIDI controller?
Best
FC
Share this post
Link to post
Share on other sites
No, there is no way with the current firmware.
Which possibilities do you have with your MIDI controller? Would SysEx be fine?
Share this post
Link to post
Hi TK,
I have a FCB1010 and I can't send sysex.
I can send a note,  program change or controller only.
Thanks for the prompt answer!
Share this post
Link to post
maybe this is slightly different from what fcerberos has in mind, but:
What if we could Tap Tempo the SEQ V4 from a remote controller, with a cc or a note or something?  I mean, it has a tap tempo button like many other devices.   It also has remote functions for external control, see http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fschematics%2Fmidibox_seq%2Fmbseqv3_remote_functions.ps. Maybe it is possible to link a remote key to the tap tempo function?
Then you would have to program the stop, start and tap tempo note to your FCB1010, which I know can be done.
Share this post
Link to post
Yes, that would also work!
I already have transport pedals assigned to the FCB at the remote location where I play another instrument.
(I'm using the FCB analog switches because for the midi remote you need to send two notes and the FCB can send
only one, and have no more left for the tap)
So yes, a note on a specific channel for tap tempo would be ideal.
Share this post
Link to post
Remote functions can also be accessed through a cc. see MBSEQ_HW.V4, you might want to try and change it.
# MIDI Remote Keyboard Function
# The note number which activates the remote function
# 96 = C-6 (some MIDI monitors display C-5)
# 0 disables the remote keyboard function
MIDI_REMOTE_KEY 96
# The CC number which activates the remote function
# (e.g. to control it with a footswitch)
# Allowed numbers: 1-127 for CC#1..CC#127
# 0 disables the function (default)
MIDI_REMOTE_CC 0
So  if you put cc 14 in instead, you activate remote mode with a cc 14 => 64 and deactivate it again with  cc<64.  Then you can save the FCB note for a remote command (play, stop, anything) (btw do you know the FCB UNO firmware?)
And maybe maybe, it will only require a minor tweak in the code to get remote tapping.
The code for tapping tempo with a button is in seq_ui.c:  s32 SEQ_UI_Button_Play(s32 depressed)
    return SEQ_UI_BPM_TapTempo();
Then there is the remote control routine  s32 SEQ_UI_REMOTE_MIDI_Keyboard(u8 key, u8 depressed)
with an empty entry  at
    case 0x43: // G-4
      return 0; // ignore
( and E-4 & F#6) where we might try instead:
    case 0x43: // G-4
I don't know if there are other dependencies in the code, but TK will certainly know.
If my assumptions are correct, may we kindly suggest him this tiny extra functionality?
Edited by EsotericLabs
Share this post
Link to post
Wasn't aware of the possibility to use a cc for the remote functions trough the MBSEQ_HW.V4 file configurations.
Thanks for the tip!!! (I could use the analog switches for tap)
Would be nice anyway to tap with a midi note.
Best
FC
Share this post
Link to post
I have edited the MBSEQ_HW.V4 file to activate the midi remote with a CC.
I'm sending the CC and note with the FCB to the SEQ4 and in some of my
sessions it is working, but in others not!
Is there something I'm missing?
Best
FC
Share this post
Link to post
Hmm not anything I can test at this moment, but I will look into it later.
Share this post
Link to post
