electrodancer Posted March 10, 2016 Report Share Posted March 10, 2016 (edited) hi there the powered usb hub from reichtelt is not available anymore. http://www.reichelt.de/MAXXTRO-MX-UAP/3/index.html?ACTION=3&GROUPID=6103&ARTICLE=99781&SHOW=1&START=0&OFFSET=16& can anyone reccomend another suitable powered hub available at reichelt ? would this one be okay to power a seqv4? https://www.reichelt.com/USB2-95912/3/index.html?&ACTION=3&LA=446&ARTICLE=141073&artnr=USB2+95912&SEARCH=powered+usb+hub Edited March 10, 2016 by electrodancer yess Quote Link to comment Share on other sites More sharing options...
derkollo Posted March 10, 2016 Report Share Posted March 10, 2016 Hey the alternative you linked has 2A. In the Seq Manual it states 400-1000mA. So the hub should be ok to power two Seqs without any problems. :) In my opinion the switch isn't needed. But that depends on how someone prefers his setup... Greetz Quote Link to comment Share on other sites More sharing options...
Hawkeye Posted March 10, 2016 Report Share Posted March 10, 2016 If you are looking for "switchability", there is also a quite cheap alternative to powered usb hubs with switches - just use usb cables with integrated power switches :-) https://www.adafruit.com/products/1620 (These are also available with a mini/micro usb socket) Then you can power from any (chinese) USB wall wart adapter (rated at 5V/1A) you may have lying around... Not that this is the recommended way to obtain clean 5V, but it is cheap! :-) Many greets, Peter Quote Link to comment Share on other sites More sharing options...
Keeze Posted March 10, 2016 Report Share Posted March 10, 2016 You could consider https://www.sossolutions.nl/hub-met-schakelaars If you want to source it in Holland. Quote Link to comment Share on other sites More sharing options...
electrodancer Posted March 12, 2016 Author Report Share Posted March 12, 2016 thanks for the replies guys ! Quote Link to comment Share on other sites More sharing options...
mfk Posted March 13, 2016 Report Share Posted March 13, 2016 https://www.reichelt.com/USB-Hubs/LOGILINK-UA0148/3/index.html?&ACTION=3&LA=2&ARTICLE=127214&GROUPID=6103&artnr=LOGILINK+UA0148 works well Quote Link to comment Share on other sites More sharing options...
