hi there
the powered usb  hub from reichtelt is not available anymore.
http://www.reichelt.de/MAXXTRO-MX-UAP/3/index.html?ACTION=3&GROUPID=6103&ARTICLE=99781&SHOW=1&START=0&OFFSET=16&
can anyone reccomend another suitable powered hub available at reichelt ?
would this one be okay to power a seqv4?
https://www.reichelt.com/USB2-95912/3/index.html?&ACTION=3&LA=446&ARTICLE=141073&artnr=USB2+95912&SEARCH=powered+usb+hub
Edited by electrodancer
yess
Hey
the alternative you linked has 2A. In the Seq Manual it states 400-1000mA.
So the hub should be ok to power two Seqs without any problems. :)
In my opinion the switch isn't needed. But that depends on how someone prefers his setup...
Greetz
If you are looking for "switchability", there is also a quite cheap alternative to powered usb hubs with switches - just use usb cables with integrated power switches :-)
https://www.adafruit.com/products/1620
(These are also available with a mini/micro usb socket)
Then you can power from any (chinese) USB wall wart adapter (rated at 5V/1A) you may have lying around...
Not that this is the recommended way to obtain clean 5V, but it is cheap! :-)
Many greets,
Peter
