Phatline Posted March 23, 2016 Posted March 23, 2016 I want to program my own software running on the "Generic" SEQ-CS-Wilba - UI- PCB (Software: Triggermatrix) it has nothing to do with the SEQV4, except the BPM part, so ripp off the UI-Code for the Button-Matrix from SEQV4 is a no go > i dont understand it. i first wrote a small app to show me DIN-PINing off all Btns, (following Pins have a offset off 4 Shiftregisters ... because a MB-LRE-8x2CS is in the chain) then realized that not every btn has its very own PIN...ok i thougt, i know such things from LEDMatrices the other way arround. But Scan Matrices (BTNs) is newland for me... i quick search give me: mios32/trunk/apps/examples/fastscan_button_matrix_16x16 <<< should i start with that, or is there a more simple/better for learn-Code somewhere thanx MB-LRE8x2CS ROW 1 ENC 0 1 2 3 4 5 6 7 SR 1 1 1 1 2 2 2 2 Pin 0 2 4 6 0 2 4 6 MB-LRE8x2CS ROW 2 ENC 8 9 10 11 12 13 14 15 SR 3 3 3 3 4 4 4 4 Pin 0 2 4 6 0 2 4 BNT-SCAN-Matrix Nr. 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 BTN 46 46 LED BTN 47 47 LED BTN 46 46 LED BTN 47 47 LED BTN 47 47 40 41 40 41 40 41 40 41 40 41 40 41 40 41 40 41 LED BTN 47 47 43 42 43 42 43 42 43 42 43 42 43 42 43 42 43 42 LED BTN 47 47 45 44 45 44 45 44 45 44 45 44 45 44 45 44 45 44 LED
latigid on Posted March 24, 2016 Posted March 24, 2016 As far as I know, there's no circuit diagram for the SEQ PCB, but you could trace the layout pretty easily. Are you familiar with the concept though? A button matrix scans inputs via DIN and sends pulses on the DOUT chain to close the circuit. It's not high-level programming, but you could load up MB_NG and define a button matrix to test the concept. @Sauraen just made a CS for his SEGA Genesis build, perhaps he has some advice.
Phatline Posted March 24, 2016 Author Posted March 24, 2016 the concept sounding logical.... i think i have something seen here http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Ftutorials%2F029_keyboard_velocity%2FREADME.txt no, mb_ng is to big (cant understand code which i havent programmed myself, or stripped down to the minimum working task) have to try to strip down the tutorial 29 code, by remove the Velocity calculating.
TK. Posted March 24, 2016 Posted March 24, 2016 The BLM_X is the right choice (and not the KEYBOARD driver) Programming Example: http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fexamples%2Fblm_x%2F Following configuration is required in mios32_config.h: // configure BLM_X driver #define BLM_X_NUM_ROWS 8 #define BLM_X_BTN_NUM_COLS 8 #define BLM_X_LED_NUM_COLS 8 #define BLM_X_LED_NUM_COLORS 1 #define BLM_X_ROWSEL_DOUT_SR 1 #define BLM_X_LED_FIRST_DOUT_SR 2 #define BLM_X_BTN_FIRST_DIN_SR 2 #define BLM_X_ROWSEL_INV_MASK 0x00 #define BLM_X_DEBOUNCE_MODE 1 Schematic which shows the DIN/DOUT mapping: http://www.ucapps.de/midibox_seq/mbseq_v4_dio_wilba_layout.pdf Best Regards, Thorsten.
Sauraen Posted March 25, 2016 Posted March 25, 2016 18 hours ago, latigid on said: @Sauraen just made a CS for his SEGA Genesis build, perhaps he has some advice. BLM_X works well and was relatively easy to use. I even fixed a couple bugs in it along the way. :)
Phatline Posted March 25, 2016 Author Posted March 25, 2016 (edited) yesss... Triggermatrix is on the way to generic SOFTWARE: i stripped it a bit, and something... to find the pinning... and with pinning its easyer to program.... UI__SEQ-CS+LRE8x2CS.zip HARDWARE: STM34F4 CORE [J8/J9] > [J1]MB-SEQ-CS-Wilba[J2] > [IN]MB-LRE8x2CS-Fairlightii MB-SEQ CS BLMx ENCODERS BTN 62 54 ENC 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LED 59 50 SR 1 1 1 1 3 3 3 3 4 4 4 4 5 5 5 5 BTN 63 55 PIN 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 LED 58 49 BTN 46 38 ENC 16 JOG LED 57 34 SR 6 BTN 47 39 PIN 2 LED 56 33 BLMx BLM+x BTN 14 30 32 33 40 41 48 49 56 57 24 25 16 17 8 9 0 1 LED 10 26 39 38 37 36 47 46 45 44 55 54 53 52 63 62 61 60 31 30 29 28 23 22 21 20 15 14 13 12 7 6 5 4 BTN 15 31 35 42 43 50 51 58 59 26 27 18 19 10 11 2 LED 9 25 35 43 42 51 BEAT BTN 6 22 37 44 45 52 53 60 61 1 28 29 20 21 12 13 4 LED 8 24 0? 41 40 48 18 19 11 3 2 MB-LRE8x2 CS 2.5 in seriell to MB-SEQ CS Wilba ENC 0 2 4 6 8 10 12 14 SR 7 7 8 8 9 9 10 10 PIN 0 4 0 4 0 4 0 4 ENC 1 3 5 7 9 11 13 15 SR 7 7 8 8 9 9 10 10 PIN 2 6 2 6 2 6 2 6 Edited March 25, 2016 by Phatline
