Zam Posted May 14, 2016 Posted May 14, 2016 (edited) Hi all From .NGC, I try without success to have midi data I/O with RTP-midi (kissbox) connected at J16 (J1 at BEB card) I'm able to send midi with .NGR and SPI1 port definition, but I want to send receive midi with .NGC configuration How can I do that? "ports=" definition at .NGC don't seem to have SPI choices... I'm lost here. Also I have trouble to update/load data with MIOS studio, I connect to the core, browse and edit config files, but there is error if updating/saving the change. Another example, if I type "help" at MIOS studio terminal, the text with all available command is just crazy, missing parts and wrong "return to line" I'll appreciate help on this best Zam Edited May 14, 2016 by Zam
TK. Posted May 22, 2016 Posted May 22, 2016 Hi, according to the documentation following port mask should enable SPI1: ports=00010000000000000000 Best Regards, Thorsten.
Zam Posted May 22, 2016 Author Posted May 22, 2016 (edited) Hi Thorsten Thanks !!! Did you just upgrade the documentation, because I miss this couple days ago, when I read for the hundred time again the documentation I will try asap juste a note/question according to the example you give, SPI is first 4 digits not last 4 digits, and fourth digit enable SPI 4, if I'm logical ? Quote Expects a 16bit binary value (0|1) to select the MIDI ports over which the event should send and receive: the first 4 digits enable/disable USB1..USB4 the next 4 digits enable/disable MIDI1..MIDI4 the next 4 digits are reserved, don't use! the next 4 digits enable/disable OSC1..OSC4 the last 4 digits enable/disable SPI1..SPI4 (requires that the spi_midi flag has been enabled in the MIOS32 Bootloader configuration. Example: following binary value (which is the default value) ports=00001000100000001000 will enable USB1, MIDI1 (IN1 and OUT1) and OSC1, and following binary: ports=00000000110000000000 will only enable MIDI1 and MIDI2 ports=00010000000000000000 will enable SPI1 Best Zam Edited May 22, 2016 by Zam
TK. Posted May 23, 2016 Posted May 23, 2016 Yes, I added it yesterday (the documentation was only in the source code) "binary logical" the first digits are at the right side, and the last at the left side. Best Regards, Thorsten.
Zam Posted May 23, 2016 Author Posted May 23, 2016 Hello Thorsten Ok that's great it work now !!! fader moves without USB connected I just made a quick change at .NGC to check, don't have time this week to go further on this i'm in a middle of mix session. Sorry but to make it work right now I have to define ports=00000000000000001000 and not ports=00010000000000000000. there is some contradiction between text/description and example, but I solved this in few min, as I get the point of 16bit in place of 12bit for the ports definition. Everything is fine Best Zam
