@Phatline : It really looks quite the same than in the schematic, at least to me  did not looked well . My bad once again.
Edited by Psykhaze
1 hour ago, Psykhaze said:
@Phatline I am coming back to the Accent Signal. Is it 15V Bipolar or not?
No it is in a Range from +4 to +15V (with the 4 i am not really sure), it simply feeds Q29 with Power -negative Polarity would not make sense-
- the Base of Q29 is shortley triggered with the Trigger Signal - coming from Q28,
Q29 now switches thru for about 1ms - with the Accent-Voltage - coming from AOUT_LC .... the other Stuff after Q29 are then is a Envelope. (as far i understand the circuit)
Sometimes some circuits are dealing with bipolar inputs by inverting the negative part, that's why i asked . So it's positive voltage feeding but not from zero and up to +15V.
Thanks you for this precision =)
Edited by Psykhaze
Also , good ideas about LEDs!
About the mixed output, i think it would be good to have separated output for each part (HH/OH/CYM/BD/SD) in addition of the mixed one
Edit : I would keep SD/BD in plugs internal and Gain pots on its specific panel
Edited by Psykhaze
  • Like 1
agree with SD and BD Plugs and Gain.
i would preefer Trigger LED located near Decay Pots (because the trigger is a envelope thing)
individual outs > ok > so we need special plugs, which cut the conection to the mix bus - i know that most 6,3er Plugs can handle that, do you  a 3,5er plug which can handle this?
yup,was just for concept.
By the way I almost finished the frontpanel first design , i send it to you by pm very soon-
I had it divided in 3 : 2 widths for Cym/HH,one central width for mix and 1 width for BD/SD. You will see the potential =)
Edit:the name of such plug seems to be solder lug jack plugs>  can be soldered direct on pcb : http://www.mouser.fr/ProductDetail/Kobiconn/161-MJ355W-EX/?qs=sGAEpiMZZMv0W4pxf2HiV0rxut4lN%252btKJQ4LNm5YrRs%3d
Edited by Psykhaze
the Plug seems ok, when using it with extra Mix-Section (no cut off the signal path needet)
my heavy modet 606...
Phats-606.thumb.JPG.5c50fb88cd6ffc535dd8
Core-Sandwitch-Conflicts
Core-Sandwitch.thumb.JPG.7a03fa8caba3fe3
Bildschirmfoto_2016-06-14_22-21-12.png.7
Bildschirmfoto_2016-06-14_22-59-26.thumb
Edited by Phatline
  • Like 1
