Psykhaze Posted June 2, 2016 Posted June 2, 2016 sure :D A resistor Array is much better in here , i talked without reading. my bad
latigid on Posted June 2, 2016 Posted June 2, 2016 Agreed, bent resistors suck, but you can place a 1206 in the same footprint. Look at this network from the same series: Might be interesting.
Psykhaze Posted June 2, 2016 Posted June 2, 2016 (edited) Hey that res networks sounds cool =) Edited June 2, 2016 by Psykhaze
Phatline Posted June 2, 2016 Author Posted June 2, 2016 Just now, latigid on said: Look at this network from the same series: complex - but not what aout_LC need...: aout-lc-scheme -i think-
Psykhaze Posted June 2, 2016 Posted June 2, 2016 (edited) @Phatline : It really looks quite the same than in the schematic, at least to me did not looked well . My bad once again. Edited June 2, 2016 by Psykhaze
latigid on Posted June 2, 2016 Posted June 2, 2016 @Phat You're right, I don't think it will work, sorry about that.
Psykhaze Posted June 2, 2016 Posted June 2, 2016 @Phatline I am coming back to the Accent Signal. Is it 15V Bipolar or not?
Phatline Posted June 2, 2016 Author Posted June 2, 2016 1 hour ago, Psykhaze said: @Phatline I am coming back to the Accent Signal. Is it 15V Bipolar or not? No it is in a Range from +4 to +15V (with the 4 i am not really sure), it simply feeds Q29 with Power -negative Polarity would not make sense- - the Base of Q29 is shortley triggered with the Trigger Signal - coming from Q28, Q29 now switches thru for about 1ms - with the Accent-Voltage - coming from AOUT_LC .... the other Stuff after Q29 are then is a Envelope. (as far i understand the circuit)
Psykhaze Posted June 2, 2016 Posted June 2, 2016 (edited) Sometimes some circuits are dealing with bipolar inputs by inverting the negative part, that's why i asked . So it's positive voltage feeding but not from zero and up to +15V. Thanks you for this precision =) Edited June 2, 2016 by Psykhaze
Phatline Posted June 10, 2016 Author Posted June 10, 2016 @Psykhaze here is the list of parameters for the HH+CY Frontpanel, maybe add 3 trigger LEDs? 1
Psykhaze Posted June 10, 2016 Posted June 10, 2016 oh cool ! I was in the wiki but i'm going in illustrator right now :p
Psykhaze Posted June 10, 2016 Posted June 10, 2016 (edited) Also , good ideas about LEDs! About the mixed output, i think it would be good to have separated output for each part (HH/OH/CYM/BD/SD) in addition of the mixed one Edit : I would keep SD/BD in plugs internal and Gain pots on its specific panel Edited June 10, 2016 by Psykhaze 1
Phatline Posted June 10, 2016 Author Posted June 10, 2016 agree with SD and BD Plugs and Gain. i would preefer Trigger LED located near Decay Pots (because the trigger is a envelope thing) individual outs > ok > so we need special plugs, which cut the conection to the mix bus - i know that most 6,3er Plugs can handle that, do you a 3,5er plug which can handle this?
Phatline Posted June 10, 2016 Author Posted June 10, 2016 yes but the slot should be mooved to 90° (standing)
Psykhaze Posted June 10, 2016 Posted June 10, 2016 (edited) yup,was just for concept. By the way I almost finished the frontpanel first design , i send it to you by pm very soon- I had it divided in 3 : 2 widths for Cym/HH,one central width for mix and 1 width for BD/SD. You will see the potential =)Edit:the name of such plug seems to be solder lug jack plugs> can be soldered direct on pcb : http://www.mouser.fr/ProductDetail/Kobiconn/161-MJ355W-EX/?qs=sGAEpiMZZMv0W4pxf2HiV0rxut4lN%252btKJQ4LNm5YrRs%3d Edited June 10, 2016 by Psykhaze
Phatline Posted June 10, 2016 Author Posted June 10, 2016 (edited) the Plug seems ok, when using it with extra Mix-Section (no cut off the signal path needet) my heavy modet 606... Core-Sandwitch-Conflicts Edited June 14, 2016 by Phatline 1
