Not sure if I am missing something obvious but in grid mode, Alt+extra row does NOT select the octave, it simply selects the respective part like if alt was not being pressed..
Also doesn't work as described on my unit.
Can we think of a different way that will work? Like Shift+Alt changes the extra row or column into a octave select? Or the idea in the feature request thread of using a slider. Even something like "hold Shift and move Slider 1 to change the currently viewed octave (jump behaviour, centre of slider = C3?). As long as Shift is held the extra column will illuminate to indicate the current window."  Because height = 16 buttons, there could be an overlap of notes, but I think it's most intuitive to maintain the current scale for the selected track.
TK. mentioned he doesn't want the BLM to rely on optional sliders, but I've never seen another in operation, and if anyone comes up with a different design they should certainly include sliders or pots!
This would be awesome.  About to recommend it.
Not as awesome, but will work.
I'm pretty sure there is very little chance of that.
  • 2 weeks later...
I guess that after some changes requested by somebody else, this function isn't working anymore.
Shows me that the "real" (not virtual) BLM16x16+X needs to be reviewed & improved, this task is already on the wish list.
No, it probably hasn't been verified and therefore probably won't work after the changes for somebody else who requested changes for the virtual interface...
Patience please, the issue is noted, I need to schedule a review & code changes at my side - which probably won't happen in the next weeks! I guess that you can life with this limitation...
Good! ;-)
To be clear on that: nothing will get lost (I've a TODO list) - but please accept that sometimes there are situations at my side which require higher attention.
Posted (edited)
didnt mean to come off like I was rushing anyone, that wasnt my intention.  I know how things work around here :)
Edited by Altitude
