dendy Posted July 18, 2016 Posted July 18, 2016 Hello please, i'm searching diy project for creating 16 in / 16 out MIDI/USB interface (i need that it supports all types of midi messages inclucing systex) ... is it possible to create such project with ucapps platform ? Any advice welcome, thanks ...
Zam Posted July 18, 2016 Posted July 18, 2016 Hello Dendy MBHP and MIOS support 4x4 midi DIN port and 4x4 usb midi Best Zam
Rowan Posted July 18, 2016 Posted July 18, 2016 If you are using a Mac I would suggest buying 2x Emagic AMT8. These can be chained together for 16x16 I/O. They are pretty cheap second hand and will cost a lot less than a DIY solution.
Hawkeye Posted July 18, 2016 Posted July 18, 2016 You might get an 8x4 or 12x4 (with a bit of hacking) MIDI USB interface with up to 12 DIN outs on a 32-bit MIOS based platform running, when using IIC_MIDI modules, but it is true, 16x16 is currently not obtainable without serious hacking ;-). But then, the inbuilt MIDI router of all modern 32-bit MIOS firmwares (SEQv4, MIDIO128, MBNG...) is really great, you can control it e.g. via a small SCS board without computer. And then, some operating systems will allow to attach multiple MIDIboxes to your USB ports (windows sometimes has problems with MIDI port enumeration, but I've got a MBNG, a SEQ and a custom project (MBLoopa) attached to a single Windows 10 machine and it works somehow). :-) Many greets, Peter
