Molom Posted May 12, 2017 Posted May 12, 2017 Hi guys, I've finished building the base of a mb6582 (including display) and so far everything seems to work as it should (Woohoo!). However, after reading Hawkeye's CS tutorial, I've delayed soldering components onto the control surface PCB until the front panel that I've ordered arrives. Until then, I'd like to rig up a minimum CS using a breadboard and switches/encoders for basic parameter changes (menu scrolling, etc). Is this possible, and if so how? Even with TK's instructions I'm not quite sure how to go about it.
r0main Posted May 18, 2017 Posted May 18, 2017 Hello, donyou know where I can find pcb/pcb clone for the mb6582? thanks, romain
Molom Posted May 18, 2017 Author Posted May 18, 2017 (edited) You won't find any clones. Your best chance is to contact Tim at Midibox Shop and be patient. Edited May 18, 2017 by Molom
gerald.wert Posted May 18, 2017 Posted May 18, 2017 (edited) Use http://www.midibox.org/dokuwiki/doku.php?id=default_encoder_assignments to map the menu encoder connections. and http://www.midibox.org/dokuwiki/lib/exe/fetch.php?media=mb-6582:mb-6582_cs_din_wiring.pdf to map the buttons you need. The buttons are in a matrix you just need the buttons and a diode each. No matrix on the encoders. You would just jump off the headers on the main board to your temporary cs board. All you need for buttons are the menu button and the 5 select buttons. Everything else you can access from the software. Edited May 18, 2017 by gerald.wert
