goyousalukis Posted January 20, 2019 Report Share Posted January 20, 2019 Hey guys, I am looking for some help. I have a MBSeq4 with an AOUT NG connected with the line driver/receiver. 6 of the channels are working perfectly, but I have two issues: When I test the calibration for each channel with the output set at 8V, I get a constant 11V at output 5, and 0V at output 7. I have checked continuity between the outputs and the opamp, along with verified the resistance. I have also verified continuity between the opamp and the DAC. When I measure the voltages on the DAC pins for a working channel, I get 3V. When I check output 5, it has 4v, and output 7 has 0V. Do you guys think I fried these two pins on the DAC? Quote Link to comment Share on other sites More sharing options...
Zam Posted January 20, 2019 Report Share Posted January 20, 2019 Hey 1 hour ago, goyousalukis said: Do you guys think I fried these two pins on the DAC? To me it look like... There is not that many part at AOUT_NG... the weakest being the DAC Just double check your measure at TLV5630 output with the TL074s removed Best Zam Quote Link to comment Share on other sites More sharing options...
latigid on Posted January 20, 2019 Report Share Posted January 20, 2019 I agree with Zam: probably those DAC channels are dead (but do check directly at the pins). The TLV chip is quite sensitive to heat. Quote Link to comment Share on other sites More sharing options...
goyousalukis Posted January 22, 2019 Author Report Share Posted January 22, 2019 Thanks guys - I havent had a chance to pull the OpAmp and recheck the voltages yet. I'll probably just settle for 6 CV outs. Quote Link to comment Share on other sites More sharing options...
