I tried it now with a fresh firmware. I cloned the GitHub to get the latest version. Then I've copy/pasted the changes @TK. made into the code and compiled.
I use the core and a classic AINSER8 module. PB8 goes directly from the discovery-board to a breadboard. There is a pullup resistor to 5V. PB8 goes into the CS-input. Result: It's working fine.
If I now just change PB8 to PE8 (like in your example), nothing happens. Here is my NGC:
RESET_HW
AINSER n=1 enabled=1 cs=1 resolution=7bit num_pins=1 muxed=0
AINSER n=2 enabled=1 cs=2 resolution=7bit num_pins=1 muxed=0
Have you an idea?!
