jujule Posted June 24, 2019 Report Share Posted June 24, 2019 Hello everyone, I am completely new to MIDIbox. I am trying to get the first tutorial to compile under Ubuntu 18.04 for Core 32 STM32F4 and get the following error message : > make -s Creating object file for strtol.c /home/sojastar/Documents/Programmation/MIOS32/mios32/programming_models/traditional/strtol.c:147:19: error: expected ')' before '(' token _DEFUN (_strtol_r, (rptr, nptr, endptr, base), ^~ ) This is from a fresh ( probably faulty ) install of the toolchain : I first cloned the git repo for MIOS32 then installed the latest arm toolchain following these instructions : https://gnu-mcu-eclipse.github.io/toolchain/arm/install/ I did add the toolchain path to my PATH. Any advice or pointer would be greatly appreciated ! Thanks ! Julien Quote Link to comment Share on other sites More sharing options...
Phatline Posted June 24, 2019 Report Share Posted June 24, 2019 do you compile a standard app? or some own programmed? (> you get that message by every app you want to compile?) (i also use ubuntu - and for me its always pain in the ass - to get it running > all the librarys you have to install... luckely i dont have to fresh install my OS only once a few years...) Quote Link to comment Share on other sites More sharing options...
jujule Posted June 24, 2019 Author Report Share Posted June 24, 2019 Hey Phatline, Thanks for the quick answer. No, I just tried to compile the first tutorial project in apps/tutorials/001_forwarding_midi and the app skeleton in apps/templates/app_skeleton. Both projects give the same error. Thanks, Julien Quote Link to comment Share on other sites More sharing options...
jujule Posted June 24, 2019 Author Report Share Posted June 24, 2019 Oops, Silly me, an issue was already opened on the GitHub repo site : https://github.com/midibox/mios32/issues/3 Maybe better to focus efforts there. Julien Quote Link to comment Share on other sites More sharing options...
jujule Posted June 26, 2019 Author Report Share Posted June 26, 2019 Problem solved. I left a comment in the GitHub issue but here is a copy of it for convenience : I installed the toolchain found here : http://www.midibox.org/mios32_toolchain/ ( as I should have from the beginning but I got wary when I saw it was last updated in 2013 ) and everything works fine now but for a few warnings. Apparently the newer arm toolchain doesn't define the _DEFUN, _AND and _CONST macros ( and a bunch of other ones too ) in _ansi.h. Quote Link to comment Share on other sites More sharing options...
