prusaga Posted February 3, 2020 Posted February 3, 2020 (edited) Hello, I am trying to implement foot controller with some tactile switches. I am trying to capture a button press and send MIDI data. I have trying to use the tutorial polling_j5_pins. I have changed the user button (PA0) to get initialized. I am unable to use the button yet to send a MIDI signal to computer. Where am i missing something to capture button press. The program doesnt enter the if condition shown in second image. Edited February 3, 2020 by prusaga
Phatline Posted February 5, 2020 Posted February 5, 2020 where in the program did you put the "pin changed" code? i am pretty sure that you have to initalize the pins in the app-init, as a Digital input before.. if you have time till the day after tomorrow, i am not at home right now...
Phatline Posted February 5, 2020 Posted February 5, 2020 hi i used J5 for LED Indication, and one User-Button, see this: MSQ-CC-BCR i used this code for Initialisation: void APP_Init(void){ // LED: initialize J5A pin1-3 & J5B pin0-3 as outputs in Push-Pull Mode int pin; for(pin=1; pin<8; ++pin) {MIOS32_BOARD_J5_PinInit(pin, MIOS32_BOARD_PIN_MODE_OUTPUT_PP);} int a; for(a=1; a<8; a++) { MIOS32_BOARD_J5_PinSet(a, 0);} //Turn off all LEDs // MOMENTARY-BUTTON initialize pin 0 of J5A, as Digital input with internal Pull-Up MIOS32_BOARD_J5_PinInit(0, MIOS32_BOARD_PIN_MODE_INPUT_PU); } as exemple - in app background, for reading the J5 States: void APP_Background(void){ // Set Bet Structure without LCD but with PIN 1 of J5A static rythm = 0; // initalized once // check J5 pin 0 for changes static s16 count = 0; if ( MIOS32_BOARD_J5_PinGet(0) == 0 ) { count = 500; } if ( count != 0 ) { count--; } if ( count == 1 ) { rythm_count++; // count thru switch ( rythm_count ) { case 1: rythm = 3; break; case 2: rythm = 4; break; case 3: rythm = 5; break; case 4: rythm = 6; break; case 5: rythm = 7; break; case 6: rythm = 9; break; case 7: rythm = 11; break; default: rythm = 13; break; } } } if you want to Activate a J5 with the variable rythm_count from above (switch thru the LEDs), put it also in APP_Background for example for( x=1; x<8; x++) { MIOS32_BOARD_J5_PinSet(x, 0);} // Turn off all LEDs switch ( rythm ) { case 3: MIOS32_BOARD_J5_PinSet(1, 1); break; // Turn on one LED - Indicate rythmset case 4: MIOS32_BOARD_J5_PinSet(2, 1); break; case 5: MIOS32_BOARD_J5_PinSet(3, 1); break; case 7: MIOS32_BOARD_J5_PinSet(4, 1); break; case 9: MIOS32_BOARD_J5_PinSet(5, 1); break; case 11: MIOS32_BOARD_J5_PinSet(6, 1); break; case 13: MIOS32_BOARD_J5_PinSet(7, 1); break;} break; i am still unsure what you mean with USER-Button, if you mean one of the onboard buttons, i cant help you... stil i dont see a need to use them to initalize the J5 GPIO... i would do this in APP_Init hardcodet, or with a other DIN... however thats it from my side.
