Dimduj Posted February 4, 2020 Posted February 4, 2020 (edited) Hi I’ve a midibox seq v4+ and one thing I struggle with is that each time I switch to a new pattern I have to reconfigure all the tracks setup (midi port, midi channel, track length). i probably miss something but is there a way to define the track setup globally or even better, per session ? i try to search on the wiki, and on the forum but didn’t have any luck i don’t mind editing some files directly on the SD card if it is the way to go but all I’ve tried do not works:/ thx for any suggestions dimitri Edited February 6, 2020 by Dimduj
TK. Posted February 23, 2020 Posted February 23, 2020 Hi Dimitri, there are two ways how you can achieve this: store/restore the track setup as a PRESET: Menu->Evnt, and then PRESET with GP Button #15 or store an entire setup as a session, and if you would like to use it as a template for another session, just use the "Save As" function Best Regards, Thorsten.
Dimduj Posted March 25, 2020 Author Posted March 25, 2020 Thx for the answer TK ! I already use the PRESET ad a default SESSION for the initial setup and it works easily . What puzzle me is he fact that I have to reselect the PRESET each time I go to a new pattern. If I change my mind about some instrument config (the channel for example) I've to edit each pattern to reflect that change Is this the expected behaviour or am i missing something ? I would expect that if I choose an instrument (PRESET) for a track It will be use for every new pattern unless I choose another instrument (PRESET) for a specific pattern? Are PRESET defined per track or per pattern ? Maybe the 'Save & Take over' feature could be a workaround for my first issue. Sorry for the late reply but i try to avoid asking super dumb newbie question and it took me times to explore the features and make a correlation between user manual with Wilba workflow and the new Midipy workflow;) Thx again for the support and congrats for this amazing piece of hardware I really enjoy it !!! Take care
u-link Posted June 30, 2020 Posted June 30, 2020 Did you find a solution to this? I had my Seq for some years, and I always find the exact situation you describe unnecessarily complicated. I guess most people will assign a function to a track that'll stay the same in every session. Being able to "init" every pattern to have the same assignments would make life a lot easier. I actually work around it by switching Option 11/33: "Paste and Clear button will modify: Only steps VS. Complete Track". I then switch it back and just clear the sequence content in a next step.
