victorm Posted February 18, 2020 Posted February 18, 2020 (edited) Hello friends, I am new and this is my first project, I bought midibox sid2, the small version. My odyssey is to load the necessary software inside the pic, I have a USB charger that supports this IC. I would like to know what HEX file I have to load into the PIC or if I have to load several. I've been reading something about a bootloader (bootloader_v1_2b_pic18f4685.hex.) I also have a file inside a folder called midi. Please, if someone can explain the loading sequence of the software, it would make me a father. Edited February 18, 2020 by victorm
Rio Posted February 18, 2020 Posted February 18, 2020 (edited) hi and welcome, Do you want to drive an update? Is there already firmware on it? Then it is possible to upload the firmware (newer bootloader or newer mbsidv2) via midi. What response do you get when you use mios studio 2, connect and set "midi in" and "midi out" for your device and you press the "query" button for example for "device ID:" 0? But please don't load a hex file for it yet ... first you need to look at which ID and version the PIC is responding. Greetings! Edited February 18, 2020 by Rio
victorm Posted February 18, 2020 Author Posted February 18, 2020 7 minutes ago, Rio said: hi and welcome, Do you want to drive an update? Is there already firmware on it? Then it is possible to upload the firmware (newer bootloader or newer mbsidv2) via midi. What response do you get when you use mios studio 2, connect and set "midi in" and "midi out" for your device and you press the "query" button for example for "device ID:" 0? But please don't load a hex file for it yet ... first you need to look at which ID and version the PIC is responding. Greetings! I am going to start the process from the beginning, the pic will be deleted with the programmer, I have the pic and the programmer to burn the file you tell me. I am lost in this. What should I do first? Thanks and best regards friend!
Rio Posted February 18, 2020 Posted February 18, 2020 (edited) hi. you don't really need to burn if you still have a bootloader on the pic. the upgrades also go through midi .. PS: But if you really want to "burn", several things are crucial. I would recommend that you take a new PIC for testing and not this one that's already baked.. in any case then do not use the file in the "midi" folder. Greetings, Edited February 18, 2020 by Rio
victorm Posted February 19, 2020 Author Posted February 19, 2020 7 hours ago, Rio said: hi. you don't really need to burn if you still have a bootloader on the pic. the upgrades also go through midi .. PS: But if you really want to "burn", several things are crucial. I would recommend that you take a new PIC for testing and not this one that's already baked.. in any case then do not use the file in the "midi" folder. Greetings, I have this pcb. My pic was deleted several times, but it's still functional, I didn't know that there was a bootloader inside, so what do I need to leave my pic like the one in the photo? I charge a bootloader first? greetings and thanks for helping this newbie!
Rio Posted February 19, 2020 Posted February 19, 2020 (edited) 1 hour ago, victorm said: My pic was deleted several times, but it's still functional, I didn't know that there was a bootloader inside, so what do I need to leave my pic like the one in the photo? I charge a bootloader first? Hey, What do you mean by "deleted" exactly? What does the LCD or "Mios Studio 2" report if you connect Midi In and Out to the PC as soon as you switch on the core? And yes, the boot loader comes up first (it has its own address) Note: here are some useful docs/infos: http://www.ucapps.de/mbhp_core.html http://www.ucapps.de/mios_bootstrap_newbies.html http://www.ucapps.de/mios_bootstrap_experts.html http://www.ucapps.de/howto_debug_midi.html Greetings, rio Edited February 19, 2020 by Rio
victorm Posted February 19, 2020 Author Posted February 19, 2020 Just now, Rio said: Hey, What do you mean by "deleted" exactly? What does the LCD or "Mios Studio 2" report if you connect Midi In and Out to the PC as soon as you switch on the core? And yes, the boot loader comes up first (it has its own address) Note: here are some useful docs/infos: http://www.ucapps.de/mbhp_core.html http://www.ucapps.de/mios_bootstrap_newbies.html http://www.ucapps.de/mios_bootstrap_experts.html http://www.ucapps.de/howto_debug_midi.html Greetings, rio 104/5000 I go to the doctor now, then I make some screenshots about my studio and the lcd screen. :)
Rio Posted February 19, 2020 Posted February 19, 2020 (edited) The way to the doctor is certainly not necessary for that ;) Edited February 19, 2020 by Rio
Noise-Generator Posted February 19, 2020 Posted February 19, 2020 Indeed. There is no magic setting up this thing, you just need to follow the instructions here http://www.ucapps.de/midibox_sid_walkthrough.html at Setup the Core ... Now you need to up...
victorm Posted February 19, 2020 Author Posted February 19, 2020 3 hours ago, Noise-Generator said: Indeed. There is no magic setting up this thing, you just need to follow the instructions here http://www.ucapps.de/midibox_sid_walkthrough.html at Setup the Core ... Now you need to up... 10 hours ago, Rio said: The way to the doctor is certainly not necessary for that ;) 10 hours ago, Rio said: The way to the doctor is certainly not necessary for that ;) Hello friends, I have been reading the instructions well, I thought I was roasting the microprocessor badly. The story is that it is a project of my Father, he is 65 years old or older. XD, he bought it to do the V2. and also the minimum project with which I am now helping you. Today I discovered, after coming from fk!$ the doctor, :) the problem, the female din5 connector, you only have 1, 3, 5 pin. I could never get in touch with the core, maybe wireless. Tomorrow, if my ankle allows me, I'll go find a din5 with all the pins. Sometimes we look for problems where they don't exist. Just putting the oscilloscope on pins 2 and 3 of the octo was enough to see that there was no sign of a signal. Tomorrow I will tell you how it is, I am very grateful for your comments.
Rio Posted February 19, 2020 Posted February 19, 2020 (edited) Hey, What are you talking about - the midi port? IN or OUT? I'm not sure what you're examining. Here the schematics from http://www.ucapps.de/mbhp_core.html with all the interconnections: http://www.ucapps.de/mbhp/mbhp_core_v3.pdf Greetings, rio Edited February 19, 2020 by Rio
victorm Posted February 19, 2020 Author Posted February 19, 2020 Just now, Rio said: Hey, What are you talking about - the midi port? IN or OUT? I'm not sure what you're examining. Here the schematics from http://www.ucapps.de/mbhp_core.html with all the interconnections: http://www.ucapps.de/mbhp/mbhp_core_v3.pdf Greetings, rio missin pin 2 and 4 lol
Rio Posted February 19, 2020 Posted February 19, 2020 (edited) why did someone solder this in? it's obvious. And also check the Midi In port. yes change the MIDI Out port and then test it in mios studio. if you do not have a desoldering iron, cut the legs and remove the legs with heat using a soldering iron and pliers. Edited February 19, 2020 by Rio
victorm Posted February 19, 2020 Author Posted February 19, 2020 (edited) The problem is that the two dins do not physically have pins, maybe it is poorly manufactured. I have to buy 2 new ones with the 5 pins. Edited February 19, 2020 by victorm missin pic
victorm Posted February 20, 2020 Author Posted February 20, 2020 Hello, today I took a big step, I managed to install the bootloader, then install mine and later the file midibox_sid_v2_044, I'm trying to investigate what is sid_filter_table.hex setup_sammich_sid.hex, I don't know if I should install them too. The project sounds, I tried with ableton and get to hear an oscillator and send notes. I was testing with the CTRL guide to be able to handle more parameters by running the program under ableton live as a vst, but I haven't gotten it to work yet. Little by little . Some of you have worked some graphic version to control the midibox_sid program. Greetings And happy Thursday! :)
Noise-Generator Posted February 21, 2020 Posted February 21, 2020 No, you don't need to install more than setup 8580 or 6581 relating to the sid chip you use. Do you know/use this panel? https://ctrlr.org/midibox-sid-v2/
victorm Posted February 26, 2020 Author Posted February 26, 2020 On 21/2/2020 at 11:24 PM, Noise-Generator said: No, you don't need to install more than setup 8580 or 6581 relating to the sid chip you use. Do you know/use this panel? https://ctrlr.org/midibox-sid-v2/ Hello friend, sorry for the delay, I had a week of hellish work in the workshop. I understand that setup is enough. I have tried the panel that you comment from ableton live configuring midi in midi out, but it has not worked, maybe I should use some previous version of CTRL?
Noise-Generator Posted February 26, 2020 Posted February 26, 2020 I also had problems with CTRLR in the past, but I did not use it much. I remind that the problem with live was that it don't send the midi out because live "thinks" it is a vst sending audio out and I couldn't figured out how to solve this. Using an older Version of CTRLR was also a thought of mine having other problems. I still don't know if this would help in some cases but that is why I build Control Surfaces to my Midibox Synths, to be independent from software which could be obsolet and unsupported. What you can do is to send a lot of CCs with live which is supported (I think) I don't use live. This is the chart for CCs https://github.com/midibox/mios8/blob/master/apps/synthesizers/midibox_sid_v2/doc/mbsidv2_cc_chart.txt However, it looks complicated, I can't explain it exactly to you because I have no big experience. I have a VST which I need to search because it isn't online anymore, I can upload this. But I recommend you to build a Control Surface not only because it is really great (TYVM Thorsten) it offers also some really cool features, like wavetable editing and Sequencer and you just don't recognize it if you haven't built one. (1 LCD, 2xDinX and a Bankstick is the simplest Version)
Noise-Generator Posted February 26, 2020 Posted February 26, 2020 The VST I mean is SIDKONTROL but it seems it's just for MBox SID V1 and it looks that there are problems with A Live here´s the Topic
Noise-Generator Posted February 27, 2020 Posted February 27, 2020 I forgot, you can use CTRLR standalone. 1
