doc Posted January 25, 2004 Posted January 25, 2004 Hi all,back again on the ground.I have some troubles with the USB Module. I build four of them but I get NONE to work.Operating System Win2000.First everything looked great. I connected the module and installed the driver. The driver is named: "Cypress EZ-USB (2131Q/2131S/2135S) - EEPROM missing "The I started the EZ control-panel and did the download, did the "Vend Req" thing, and burned the eeprom as told in TK's "How to.." Still everything seemed to be fine.I closed the Control panel. and did a restart on Win 2000(German: "Alles gut macht der Boot..." ;DAfter the restart I looked in midi-Ox for the new Audio-Device. It should be there, or not ?I didn't found a new device anywhere.The USB Module is still in the device manager with the name: "Cypress EZ-USB (2131Q/2131S/2135S) - EEPROM missing "OK. Then I tried the second USB module with the same problems.The I tryed to do the eeprom grocess again. Now I have several problem. After doing the download, I didn't get the system to do the "Vend Req". When I open the "Show pending" Windows I see that it's still pending. Nothing I can do against this.I tryed all the programming steps again on another midiport. I reprogrammed the eeproms again and still had now new "Audio device".On the new USB Port I tried to programm once again. But the second time I still have the "Show Pending" - problem.What shall I do ???
TK. Posted January 25, 2004 Posted January 25, 2004 Hi Doc,it could be a problem with Win2k, because two other users reported the same problem, they are not able to get the MBHP_USB running under this OS. One of them tried the same module under WinME, and there it works fine. It also works under WinXP and Linux - so it must be a M$ issue. Maybe the Microsoft Knowledge base gives you some input?Best Regards, Thorsten.
doc Posted January 25, 2004 Author Posted January 25, 2004 Thanks T,i'll search there.Can you give me some keywords to search for ?Thanks again.doc
TK. Posted January 25, 2004 Posted January 25, 2004 "USB midi" or "USB audio device"Best Regards, Thorsten.
TK. Posted January 25, 2004 Posted January 25, 2004 P.S.: if there are vendors which also provide a USB interfaced based on the standardized USB MIDI protocol, you will maybe found a troubleshooting guide (or an alternative driver) on their site.I haven't found the time to search for such solutions yet (since I don't have access to a Win2k computer, I cannot test it)Best Regards, Thorsten.
doc Posted January 25, 2004 Author Posted January 25, 2004 Thanks again,...the M$ Knowledge Base gave nothing new for me. Still searching ....But theres something I tried:I searched the forum for other users having simular problems.I tried to download the .hex file (instead of eeprom the iic file). After that win2000 recognizes a USB Audio device.Sure it's gone after power down. But now I think I have a problem with the EEPROMing. Am I right ?Do you think, that the strange behavior in the control-panel depends on the operating system , too ?(The problem, that the usb always hangs after the "Vend Req" Button pressed. The Pending Operations window displayes: " Pending: Opindex=46: Optype=3=Vendor Request ").I think I'm not able to load the EEPROM then. I don't know, what this "Vend Req"-thing does exactly, but can I program the EEPROM with my "universal programmer" instead ? (I have a ELV programmer which supports several EEPROMS from microchip).doc
TK. Posted January 25, 2004 Posted January 25, 2004 Hi Doc,very interesting.Yes, you can burn the EEPROM with any programmer, it could also be programmed via a MIOS core like a BankStick (which would solve D2k's problem), but for this I've to prepare a special .syx fileBest Regards, Thorsten.
doc Posted January 25, 2004 Author Posted January 25, 2004 Thank you again,I try it with the ELV programmer first.But... which file shall I program? The .hex file or the .iic file ???If it doesn't work I'll ask you again for a .syx file to upload it via MIOS.Thank you TKdoc
TK. Posted January 26, 2004 Posted January 26, 2004 I don't know the ELV programmer, if it can ready .hex, then use the .hex file, if it allows to upload a binary, then use the .iic fileHowever, I've now uploaded a new package version of MBHP_USB which contains a .syx file with the V1.1 firmwareJust follow the instructions which are given in the README.txthttp://www.ucapps.de/mbhp/mbhp_usb_v1_1b.zipBest Regards, Thorsten.
doc Posted January 26, 2004 Author Posted January 26, 2004 Hi TK,sorry to disturb you again.I still don't get my four USB Modules to work. None of them.I tried it now on Win2000 (2 different PC's), on WinXP and on a old Win98.Today I tryed to program the eeprom with the .syx MIOS file. This part works fine. But when I plug the EEPROM in the USB modul, the PC recognizes still a "Cypress EZ-USB (2131Q/2131S/2135S) - EEPROM missing " device.No way to get a "USB Audiodevice".As mentioned before: When I download the mbhp_usb.hex file with the EZUSB Control Panel, the PC recognizes a "USB Audiogeraet" (and it works fine till power down ;))So the problem doesn't seem to be the eeprom. But what else ?Back to the EZ Control Center I start again doing the stuff told in your "How to ..." file. The steps:1.) Plug in the USB device without EEPROM (PC recognizes: "Cypress EZ-USB (2131Q/2131S/2135S) - EEPROM missing " device" 2.) I start the EZUSB panel, plug in the eeprom and press download to upload the vend_ax.hex file.The output window tells a lot of hex stuff and ends with:"Toggle 8051 reset"When I press the "Get dev" Button (just to test) I get the following messages:Device Descriptor: bLength: 18bDescriptorType: 1bcdUSB: 256bDeviceClass: 0xffbDeviceSubClass: 0xffbDeviceProtocol: 0xffbMaxPacketSize0: 0x40idVendor: 0x547idProduct: 0x2131bcdDevice: 0x4iManufacturer: 0x0iProduct: 0x0iSerialNumber: 0x0bNumConfigurations: 0x1I'm not able to send the Vedor Request things anymore. This only worked the first time. I only can send a Vendor Request with the following param.:Req 0xA9 Value 0x0000 Index 0xBEEF Length 1 Dir 1 IN Hex Bytes FFThen I get a message:Vendor Request0000 CD --- why CD and not FF ??If I send a Venor Rrq. with Dir 0 Outnothing happens anymore. The chip "hangs"When I open the Pending window it shows the Pending message:Pending: OPindex=51 : OP Index = 3 = Vendor RequestThat was it. Theres no change to do something more. You have to disconnect /connect the module again. Don't know what to do now.Are the Cypress chips faulty (all four ??) ?Is there a way to 'delete' the cypress chip and the eeprom just to start from new ??Why does it work when I download the mbhp_usb.hex file ?What is the "VendReq" thing. Why does it only work once ?A lot of questions for now. I have to wait for the answers and do something else instead.....Thanks,doc
TK. Posted January 26, 2004 Posted January 26, 2004 Your Chip is working and it's normal that the vendor request hangs up when the vend_ax.hex firmware is not loaded.Once the MBHP_USB firmware is running, the control panel will report, that no Cypress device is detected... so it seems that the firmware is not loaded from EEPROM during power-on.I guess that there is a problem between the EEPROM and the cypress chip, could you please measure the voltages at pin 1 & 8 (-> 3.3V against Vss) and 2, 3, 4, 7 (-> -3.3V against Vdd) first?The voltages at Pin 5 & 6 should also be 3.3V against Vss (the EEPROM will only be accessed during the first miliseconds after reset)See also: http://www.ucapps.de/mbhp/mbhp_usb.pdfBest Regards, Thorsten.
doc Posted January 27, 2004 Author Posted January 27, 2004 Thank you again for your quick replay,I checked the voltages. I have only 3.0 - 3.15 V. Could this be the problem ?By checking the schematic against your layout I recognized, that PIN 2,3,4 are connected to ground in the schematic. But not on the PCB layout. There only pin 4 is connected to ground. Pin 2 and 3 and 7 are going to the 100n cap and a 470 Ohm resistor near the power led.Is this correct ?Here are the result of the Voltage check:EEPROM in his socket:Gnd from the Power connector:Gnd - Pin1,8 = 3.2 VPin 1(+3.3V) - Pin 2,3 = 0 V (!?)Pin 1(+3.3V) - Pin 4 = 3.2VGnd - Pin5 = 3.2VGnd - Pin6 = 3.2VPin1 - Pin7 = 0VDo you think the same. 8) Could it be the layout ?Can you check this ?Thanks againDOC
doc Posted January 27, 2004 Author Posted January 27, 2004 I have it !!! :D :D :DIt's really the layout :PI connected Pin 3 and 4 of the eeprom together and guess what .....It worked !(Now the Power LED is lightning...I didn't recognized this damned LED till now !)Now the EZ Control Panel worked fine and I get 2 times 0000 FF and the eeprom is programmed also !I'm happy ! ::)Could you please check the layout. I think the pins should be connected there also.Thanks again,doc
TK. Posted January 27, 2004 Posted January 27, 2004 Great! :)Did you create the PCBs by yourself?I just noticed that the .gif contains the wrong snapshot, but the layout data in .brd is correct once you enter the "ratsnest" command - I will fix this.Best Regards, Thorsten.
doc Posted January 27, 2004 Author Posted January 27, 2004 No,I took your layout. In my .brd file there is also the connection missing. What is the 'ratnest' - command ?ThanksDoc
TK. Posted January 29, 2004 Posted January 29, 2004 "rastnest" renders the layout again, thereafter you will see a ground plane between the pins (which fortunately also can be found on Mikes premade PCBs)SmashTV has updated the .brd file - thanks! :)Best Regards, Thorsten.
moebius Posted January 29, 2004 Posted January 29, 2004 :-[ Isn't rastnet "air wires" or jumpers or something..I don't understand, what it really has to _do_ with any signals? ??? Go, Eegle , go..Bye, Moebius
doc Posted January 29, 2004 Author Posted January 29, 2004 Thanks TK,next time I print the layouts from Eagle I'll pay attention on that.Doc
