Instant and cheap PCBs.
  • Replies 70
  • Created
  • Last Reply
Top Posters In This Topic
I haven´t found any internet shop selling cpm6.3.
I supposse that I could buy it for you and send to Israel or any other country without a local reseller.
You can see the price (euros) in this image (I don´t remember whether vat is included or not).
hi
sorry but i am having hard time to get the proper info
is the price per sheet, then it s 48 euros for a box
jfmateos which model do you advice for pcb
have you ever tried pnp blue, how does it compare
thanks
simone
Yes, it´s 48 eur per 100 A4 sheets.
I have never used blue press and peel because it´s much more expensive (in Spain, at least).
CPM6.3 never fails, even with two-faced pcbs.
The only caution is using a laser printer compatible with this kind of paper. Almost all modern printers are compatible, but some old models like HP 6MP, HP 5L, OkiPage 20n doesn´t work.
I use a cheap HP laserjet P1005 and the results are superb.
I would definitively recommend CPM6.3.
I use a domestic iron (temperature in between wool and cotton) during 2 minutes.
The only trick is let the pcb cool before retiring the paper (i put it in the fridge).
hola jfmateos
since i haven t figured out myself how to order in the site would you tell me how you got it
i am moving back to spain in 20 days and i d like to get a pack, i could even share one with somebody, kartoshka maybe
hi
let s say that a mini bulk order has already started, kartoshka please confirm that you want to get some as well.
simone
  • 5 weeks later...
So here is the deal, shipping of 25 or 33 sheets at the first 2 persons joining, shipping from Spain.
Simone
can we use this technique to make lettering on frontpanel ?? i've seen a webpage where the guy explain how to make painting with transfer and printer and acid!!
  • 10 months later...
This is added in case anyone is still playing with the thing:
I played around with lazer/toner/glossy paper to make circuits boards and met with varying success.
The paper is most important, and I found some which was intended for printing glossy photos (a certain Kodak paper from Staples), and the quality was also affected by the toner etc.
Interesting, but very time-consuming. I might get into it properly one of these days, and see if there is a solid repeatable method.
I have half of a board left over from those days (a Pic18F452 Midi Saxaphone) and you can just make out the two Xtal (10Mhz crystal) capacitors still in situ.
Notice I avoided taking tracks between pins. It can be done but its not worth the effort.
cheers all
