RANGE command does not work with Receives / Senders
Hey,
I'm trying to split an incoming MIDI signal into two zones just like this:
EVENT_RECEIVER id=1 type=NoteOn key=any fwd_id=SENDER:1 range=0:36
EVENT_SENDER   id=1 type=NoteOn key=any range=0:36  chn=1 ports=100010000000
EVENT_RECEIVER id=2 type=NoteOn key=any fwd_id=SENDER:2 range=36:127
EVENT_SENDER   id=2 type=NoteOn key=any range=37:127  chn=2 ports=100010000000
Unfortunately the "range" parameter has absolutely no effect here. Regardless what values I enter, it does output two NoteOns for each key (one on ch.1 the other on ch.2) over the whole range. It does have an effect on the velocity though. I could limit the velocity through the range-parameter. But thats not what I want to do :-)
Is that a bug in the firmware? And if yes, who can fix it? :-)
Thanks,
Chris
Edited by FantomXR
Hi Chris
IIRC range= is not a split but a scale function, so range=0:36 change value 0-->0, 127-->36 and linear ponderation in-between.
maybe try with conditional function, if_=
Cheers
Zam
1 hour ago, Zam said:
Hi Chris
Cheers
Zam
Thanks for your reply.
How could "if_" help here?
What I now did (and what worked) is to create an EVENT_RECEIVER for every single note like
EVENT_RECEIVER id=1 type=NoteOn key=20 fwd_id=SENDER:1
EVENT_RECEIVER id=1 type=NoteOn key=21 fwd_id=SENDER:1
EVENT_RECEIVER id=1 type=NoteOn key=22 fwd_id=SENDER:1
Since they all listen to the same ID, its easy to activate / deactivate that with meta events. This is not beautiful because it's a lot of code. But at least its a working solution ;-)
it's a conditional, it will activate the event according to value
don't remember precise form, I don't write NGC since years now, but something like if_less=37, your receiver will forward only data from 0 to 36
This might also be valid only for the velocity but I'll give it a try!
