TK. Posted October 19, 2023 Report Posted October 19, 2023 Under http://ucapps.de/mios_studio.html we can now find a re-released version for MacOS which natively supports Intel and Apple Silicon (M1, M2, ...) based HW without the need to run Rosetta2 This change required to switch to the latest JUCE 7.0.7 version However, there are no functional differences, and especially no new MIOS Studio features (currently nothing new planned for this tool) Best Regards, Thorsten.
Zam Posted October 20, 2023 Report Posted October 20, 2023 Hi Thorsten Long time, hope you get well ! Crash before opening anything on my Air M1 I'll send the report in PM if that help. Best Zam
TK. Posted October 20, 2023 Author Report Posted October 20, 2023 Hi Zam, thanks for the feedback - although it worries me ;) The crash report indicates that something is going wrong before the actual application code has been started. I haven't seen this before, and therefore don't have a solution (yet). What would be interesting: what happens if you start MIOS Studio from a terminal: MIOS_Studio.app/Contents/MacOS/MIOS_Studio --batch Best Regards, Thorsten.
Zam Posted October 20, 2023 Report Posted October 20, 2023 3 hours ago, TK. said: What would be interesting: what happens if you start MIOS Studio from a terminal: I try open -a MIOS_Studio same result... Best Zam
TK. Posted October 21, 2023 Author Report Posted October 21, 2023 There is hope! Two days ago a new JUCE version has been released with an interesting message: #if ((defined (MAC_OS_X_VERSION_MIN_REQUIRED) \ && MAC_OS_X_VERSION_MIN_REQUIRED < MAC_OS_VERSION_13_0) \ || (defined (__IPHONE_OS_VERSION_MIN_REQUIRED) \ && __IPHONE_OS_VERSION_MIN_REQUIRED < __IPHONE_15_0)) // This is an error because the linker _will_ produce a binary that is // broken on older platforms static_assert (std::string_view (__clang_version__) != std::string_view ("15.0.0 (clang-1500.0.40.1)"), "The new linker introduced in Xcode 15.0 will produce " "broken binaries when targeting older platforms.\n" "To work around this issue, bump your deployment target to " "macOS 13 or iOS 15, re-enable the old linker by adding " "'-Wl,-ld_classic' to your link flags, or update to Xcode " "15.1.\n" "Once you've selected a workaround, you can add " "JUCE_SILENCE_XCODE_15_LINKER_WARNING to your preprocessor " "definitions to silence this warning."); #endif #endif So, here a new binary build with latest JUCE and -Wl,-ld_classic flags, let me know if this works: -> http://www.ucapps.de/mios_studio/MIOS_Studio_2_4_9_r3.app.zip Best Regards, Thorsten.
Zam Posted October 22, 2023 Report Posted October 22, 2023 Quote -unable to use this app version with your OS version... you get 11.7.8... 13.0 or further requested...- In practice It's a non issue for me as this computer is not the main one I use with midibox HW, also the previous version (non apple silicon) run fine on the M1 last time I check and communicate/UL data to a core. Basically just see your initial post and download the app to see, and then give feedback. Best Zam
phunk Posted October 23, 2023 Report Posted October 23, 2023 (edited) Thank you! Works fine here on M1 Pro with Ventura. Edited October 23, 2023 by phunk
