Nikolai Posted October 28, 2004 Posted October 28, 2004 Hi!I'm building a midibox, lc, though a bit alterd.I have tested it using cubase VST 32 and Midi OX, every thing works fine. The problem occurs when i set it up in Cubase SX.The buttons/leds uses Midi ON/Off msgs.When a midi msg i sent to the box the led wount go off..I think this is very strange.How have other people set up SX with their midi boxes?Thi should be rather simple., and works great in VST but not in SX. I would be greatful for any tips or experiencesThank you all, Nikolai
Nikolai Posted October 28, 2004 Author Posted October 28, 2004 Update-Further investigation shows that there is nothing worng whith my box. this is a cubase problem.Testing..Conecting a Midi keyboard and a Sound module instead of the Midi box shows the following.Key pressed on keyboard  MuteButton on mixer Turns OnPress keyboard again and the  MuteButton goes off, but no sound from the module ( the generic remote is set to Resive AND transmit)when Pressing the mute button with the mouse the sound module plays a note and holds it as long as the button is on. Correct.Conclution: When resiving a midi msg. Cubase's "Generic Remote" does not send a msg, out.Nikolai
TK. Posted October 29, 2004 Posted October 29, 2004 Hi Nikolai,I remember that the generic remote of Cubase SX is not so well maintained by Steinberg like before. In particular versions one or two functions are not working, in following versions they are fixed but other functions are failing... :-/Best Regards, Thorsten.
Nikolai Posted October 30, 2004 Author Posted October 30, 2004 Thank you clearing that up. TKI will look around in the cubase forum, and come back here and post an update, incase someone else has this problem later on. Best, Nikolai------btw.Temporary workaround is: (quite stupid) create to instances of every function, ex. ch 1 mute button, create "mute 8" and "mute 8 S". . , told you, stupid solution.hah :P
doc Posted October 30, 2004 Posted October 30, 2004 Hi Nikolai,did you the setup in SX as a generic controller ?If so, you should use the "Mackie Controller" with your LC.No problems with that emulation (except meters) in Cubase greetsDoc
Nikolai Posted October 30, 2004 Author Posted October 30, 2004 Thank you Doc!That sound like a good idea, i'll try that, only thing is that it can't be custumized in the same way as the generic driver,. but well, i'll live.Nikolai
