RowanHall Posted November 1, 2004 Posted November 1, 2004 hey all!everything is working fine except for one tiny problem.the mbsid is configured as cs stepA.when i turn the encoder to choose values/patches, some values are skipped out, therefore its quite difficult to choose what i require.it is a 24 ppr detented encoder.i assume there is an easy answer for this!thanks in advance! :)
illogik Posted November 1, 2004 Posted November 1, 2004 Hi,there are 2 detented encoder modes provided by mios; MIOS_ENC_MODE_DETENTED andMIOS_ENC_MODE_DETENTED2In the mios_tables.inc of the sid app., all the encoders are defined as "detented2 encoders". You could try changing the encoder mode to "detented", build a new sysex and upload the modified application. Don't know for sure if this will fix it but i would try it.cheers,marcel
RowanHall Posted November 2, 2004 Author Posted November 2, 2004 nice! cheers for the advice illogik!i shall check that out later on and get back to you!thanks! :)Rowan
RowanHall Posted November 3, 2004 Author Posted November 3, 2004 hey there,i am now unsure about compiling the source to make a new sysex with the above change.i was wondering if sombody could point me in the direction of some info or give me the lowdown! :)thanksRowan
illogik Posted November 3, 2004 Posted November 3, 2004 hey rowan,first open the mbsid project file in MPLAB IDE, then open the header file mios_tables.inc . Make the changes in this file like i mentioned above. When finished, build the project (F10 in MPLAB i think), and then when there are no build errors, convert the hex file you just made to sysex with convert.bat. This sysex file you can upload in your midibox.cheers,marcel
RowanHall Posted November 4, 2004 Author Posted November 4, 2004 hey marcel!thanks for all your help so far, it is greatly appreciated! :)alas i am sorry to report that changing that setting hasn't worked i'm afraid!it is possible that i have it wired wrong, its a bourns, currently its wired like the diagram with the middle pin as gnd.i also noticed speed settings? should i fiddle with these?also is it correct to assume that for every detent the value selected increases by one when turned slowly?Rowan
LO Posted November 4, 2004 Posted November 4, 2004 Just try all the diferent combo's with wiring the encoderI also had this problem until I found my pin out was slightly different
smashtv Posted November 4, 2004 Posted November 4, 2004 Hi Rowan!Sorry to see these giving you problems.....it is possible that i have it wired wrong, its a bourns, currently its wired like the diagram with the middle pin as gnd.Center pin is ground on these....i also noticed speed settings? should i fiddle with these?Yes! You are on the right track here.....From TK's SID 1.5 release notes Rotary encoders: CS_MENU_ENC_speed_VALUE allows to define the speed setting for encoder #2-#15. Although I'm using non-detented encoders, I prefer following setup: encoders in MIOS_ENC_MODE_DETENTED2 mode (reduces the resolution), CS_MENU_ENC_speed_VALUE set to 3 (by moving the encoder faster, you can sweep over the whole value range)The best setup depends on the used encoder, just try different settings.I have not used it, but enc_speed_v1_3.zip from MIOS downloads/test apps/ lets you try the different encoder modes with minimal effort.See also Where does the encoder speed thing go ?And Heeeeeeeeelp!!!also is it correct to assume that for every detent the value selected increases by one when turned slowly?RowanYes, after you set up the encoder speed.Let me know how it goes!BestSmash
RowanHall Posted November 5, 2004 Author Posted November 5, 2004 thanks for your input on this issue, its all greatly appreciated! :)i started fiddling about with the settings. set some variables in the main.asm to#define CS_MENU_USE_DETENTED_ENCODER 0// i assume that by setting this to 0 the speed for the menu encoder will be defined below?#define CS_MENU_ENC_SPEED_VALUE 2i tweaked the knob to the left and each detent selected a different patch number!! bingo!but... when i tweak it to the right, it takes several detents before the patch changes! strange indeed!any ideas? i'm confuzzled! haha!Rowan
