mb944 Posted January 22, 2005 Posted January 22, 2005 Hi there!I'm currently working on an exciting new midi project: A PINBALL(see photos)I haven't a clue with Pic programming so I'm only using the Mios hardware as an IO inteface between a VISUAL BASIC application and the pinball hardware.The pic is loaded with the default midi128 firmware.Here's the pogress so far:DAY ONE: built a DIN and connected all 38 triggers to it, ran the ball through them, Visual basic registered all the NOTE ON messages.that made my day! ;)DAY TWO:Made a Dout vectorboard and connected 25 Leds to It, programmed a simple sequence of consecutive lights:YES YES YES ;D that had me dancingOk, not much talent envolved here but its my first DOUT and It worked first go!unfortunately, when I took a closer look at sequencing, it noticed that the leds are being a bit random:Sometimes they come on, sometimes they just flicker on then stay offSometimes when I light 10 leds, the 11th simply cuts off the 10 othersMaybe I need to change the software config?My visual basic app handles midi in 3 decimals (MESSAGE; DATA1; DATA2)I've therefore been using the folowing code the light a led:144; 64; 1; (meaning NOTE ON; PIN 64; velocity 1)as i said, it will come on, But not allways first time, and if I loop the message, It will eventually turn off again, back on, flicker etc.Is there another decimal value other than 144 that would work better? does it toggle by default?I thought that My visual basic software might be unaccurate, but I have already used it in other situationsand it worked flawlessly Millisecond precise.i know something needs changing in the software anyway because at the moment, the din pin trigger their respective Dout pins, and i only wont them to send midi out.This project is definitley great fun, But I dont want to ruin it because of unaccurate Dout,especialy the next step being 25v solenoid coils on relays. I can't afford to burn them out because of a "sticky" pin >:(By the way, I'm supplying 9VDC at 500 mA to the core, could this be the problem?Thanks in advance for your interest in my project and for any advice with configuring the software.Best regards,Alexabove: playfield beforeabove: playfield after (still needs touching up, plastics and decals)above: See the midibox? ;Dabove: nice rotating elementabove: theres that core!
TK. Posted January 22, 2005 Posted January 22, 2005 Hi mb944,what a fancy project! :)I just have tested MIDIO128 on my MIDIbox SEQ and noticed exactly the same behaviour. This shocked me a little, because I don't remember that this problem occured during the implementation of the last changes. After some debugging I finally found out that in app_defines.inc the "MB_STAT_FETCH_DIN_REQ" flag is assigned to the same bit like "MB_STAT_DISPLAY_UPDATE_REQ" (a totally unexpected error) and this causes the flickering.So, when you change this flag to 1 and recompile the code, it will work.It will also work when you set the "DEFAULT_FORWARD_IO" option to 0 in main.asm (you have to do this anyhow), thats possibly the reason why there were no complaints about this error in the past, because most people don't use the forwarding option, this is only for testing the DINs/DOUTsOk, and I found out why I never saw this problem: it was one of the last changes which I've tested on my MIDIbox LC which has a graphical display. Since characters are printed out slower than on a common LCD, the possibility that the wrong bit assignment affects the DOUT is much lowerBest Regards, Thorsten.
banneduser Posted January 22, 2005 Posted January 22, 2005 I think saw something, that was resembling a cow flyin' :DWas it like a 3rd unknow bug around MIOS / ported APPS..Now TK, Would you mind being nominated for a SynthDIY Soddy? And to not break the rules, what would you consider as your favourite MB release for the Year 2004?Bye, Moebius
TK. Posted January 22, 2005 Posted January 22, 2005 Would you mind being nominated for a SynthDIY Soddy?*grin* just compare the number of code lines against the number of bugs ;-)The only thing which makes me worry each time is that now we will notice an increased number of postings where people assume software bugs before they start to check their hardware. From my experience it will take 3-4 months until MIOS applications have reached the known confidence level again ;-)And to not break the rules, what would you consider as your favourite MB release for the Year 2004?There are too much favourite MBs in the different categories, but last year no MIDIbox reached the originality of PulseBox16 (for the guys who don't remember the best design ever, here the design: http://homepage.ntlworld.com/keith.williamson/pb16--ad.jpg and here what the press said: http://homepage.ntlworld.com/keith.williamson/ecobox/images/midibox_mag.jpg)Best Regards, Thorsten.
TK. Posted January 22, 2005 Posted January 22, 2005 Just gone through the synth-diy mailings, now it's clear what you mean with "SynthDIY Soddy" - I mixed it with "shoddy" ;-)Best Regards, Thorsten.
mb944 Posted January 23, 2005 Author Posted January 23, 2005 thanks for the info Tk!I'll get activeperl downloaded and recompilebest regards,Alex
mb944 Posted January 23, 2005 Author Posted January 23, 2005 Hey Tk!Dont want you to think I was doubting the quality of your app!! Trust, me i have tried loads of leds before asking ;)obviously, i was convinced it was a hardware problem at first!You told me to change the flag in the app_defines.inc file, but he zip I downloaded contains app_defines.hShould I rename this extension?Thanks in avance, and cheer up, your work is the best in my opinion,All my friends are hooked on midiboxing, its a crazy thing!best regards,Alex
TK. Posted January 23, 2005 Posted January 23, 2005 Thanks :)app_defines.h is the right name, don't rename it, otherwise you are not able to build the project anymoreBest Regards, Thorsten.
airmailed Posted March 6, 2005 Posted March 6, 2005 this is from the pd-announce list.. it is not me.. the address of the creator is at the bottom of the post----------------------------------------------------------------Hi all,Tomorrow, there will be the first public showing of my pinball machineproject.venue : Tent, CBK (visual arts center for Rotterdam)adress: Witte de Withstraat 50Rotterdam, Netherlandstime : 20:30 starting timehttp://www.tentplaza.nl is their official site,warning: this is a very artistic flash site (and not up to date)taking overyour entire screen.The presentation is part of an evening with various Berlin Artists, andabeerstube with bratwurst.ABOUT:A slightly modified and repainted pinball machine (a 1992 DataEast) ishookedup to a computer running linux, effectively replacing the soundcard ofthepinball machine.In this first presentation, the sounds are generated by csound and thecomposition controlled by pd interpreting the many codes it receivesfrom thepinball machine in sometimes surprising ways.A play costs a Euro, and for that price you get your very owninteractiveconcert of contemporary electronic music and a chance to win anotherround,or to enter your initials or to play the fabulous multiball mode.FUTURE:I would like to invite other composers to write pieces for pinballmachine.Stay tuned for further announcements about this.ciaogerard-- electronic & acoustic musics-- http://www.xs4all.nl/~gml
