When the number of pot is increased all edits it's clear, I think it is most usefool if the edits are not clear, this way if i want control volume over 16 chanels, only i have to change the midi chanel and label and increase the pot number, this take a less time that write all edit on all pot.
Hello,
If I understand your question well, this is what I would suggest to implement  :
would it be OK if you could "copy and paste" entire parameter sets from on pot or button to another ?
Regards,
Serge
Hi Serge.
Yes, this its very usefool when I want control any parameter over 16 channels (reverb, chorus, P. change, etc...), the only edit to change it's
the MIDI chanel, and add #x to the label. Other posibility it's using a *.TXT or *.INI and convert it to sysex directly. Thanks, and I don't want give to you more work.
Hello,
yes, I can describe how you can try the other possibility :
Vmidibox can save to a INI file. You could edit this INI file, convert it back to a sysex file with Thorsten's  mk_syx script, then load this sysex back to vmidibox.
Anyway I will add the copy and past feature to the 'to do' list...
Regards,
Serge
