amando Posted September 10, 2002 Posted September 10, 2002 When the number of pot is increased all edits it's clear, I think it is most usefool if the edits are not clear, this way if i want control volume over 16 chanels, only i have to change the midi chanel and label and increase the pot number, this take a less time that write all edit on all pot.
serge Posted September 11, 2002 Posted September 11, 2002 Hello,If I understand your question well, this is what I would suggest to implement :would it be OK if you could "copy and paste" entire parameter sets from on pot or button to another ?Regards,Serge
amando Posted September 12, 2002 Author Posted September 12, 2002 Hi Serge.Yes, this its very usefool when I want control any parameter over 16 channels (reverb, chorus, P. change, etc...), the only edit to change it's the MIDI chanel, and add #x to the label. Other posibility it's using a *.TXT or *.INI and convert it to sysex directly. Thanks, and I don't want give to you more work.
serge Posted September 12, 2002 Posted September 12, 2002 Hello,yes, I can describe how you can try the other possibility :Vmidibox can save to a INI file. You could edit this INI file, convert it back to a sysex file with Thorsten's mk_syx script, then load this sysex back to vmidibox.Anyway I will add the copy and past feature to the 'to do' list... Regards,Serge
amando Posted September 12, 2002 Author Posted September 12, 2002 Hi again, I try it, thanks for all.
