chaining Multiplexers and Shift registers over longer cables
Hi there!
I would like to make several small midiboxes for differant purposes
that I can Stack and shuffle together according to the project I work on.
it would be cool to connect a differant physical controller for each VST I load in the host.
Anyway, thats the concept, here's the question:
It would be a waste to make a brand new core for each module so,
could I have say a mother midibox with external 5 PIN DIN and AIN connectors?
If so, could I go as far as scattering SHIFT REGISTERS over say 5 meters of cable  or will I loose the clock?
Thanks for any ideas or comments
;D
Hi mb944,
I can not recomment such long cables !
I once tested connection length from the DIN to the core.
Result: Everthing larger than 2 m causes random midi messages (I used flat cable).
Perhaps you have to use a shielded cable ?
I think 1 m between the shift registers should be no problem - test it !
I had the same problem. Now I use seperate Cores for each VST  ;)
greets
Doc
One option to run digital (or analog) signals over a long cables is to use a differential transmission. You could try to implement a RS-422 communication between the core and the DIN. And then chain to the next DIN in the same way. RS-422 is digital, so this rules out the AIN, but if you can live with encoders is should be doable...Speed should not be a problem with this method.
Check out this http://www.epanorama.net/links/tele_interface.html#rs422
Another option is to build a couple of current loop transievers.
http://www.epanorama.net/links/tele_interface.html#currentloop
This is just my first thougts, have't tryed them myself. Don't know if this current method could handle the dataspeed from the core...
Sorry for my bad english....
/Henrik
hi!
thanks for the suggestions!
the easiest solution seems to me to just have the din and ain pins "pluggable" instead of the chips
ok, each button/pot/knob will need an individual wire, but I only had mini boxes in mind
thanks again for the support
Alex
