Rio Posted August 6, 2005 Posted August 6, 2005 where can i find a description for the MIDIbox SID Control Surface? What I need for it?
Rio Posted August 6, 2005 Author Posted August 6, 2005 no, i need a description for the "control surface" (http://www.ucapps.de/midibox_sid_cs.html)? What are the things a need for?
raphael Posted August 6, 2005 Posted August 6, 2005 Just follow the link DRÄPPEL alredy gave you.And you willfind this (Step A IS the CS!!!): Control Unit (Step A)Additional parts and modules: a 2x20 LCD (or larger) a MBHP_DINX1 module - premade PCBs are not available for this small circuit, so you have to build it on a vectorboard. Alternatively you could use a DINX4 module. a rotary encoder (datawheel, endless pot)A detented encoder is recommented for precise data entry an improved PSU (ca. 500 mA) 6 buttons (or more if larger LCD is used) Costs: ca. 20-25 EUR for a backlit 2x20 LCD, 1..2 EUR for the rotary encoder, 1..6 EUR for all buttons (depends on the quality)
