Rio Posted August 6, 2005 Report Share Posted August 6, 2005 where can i find a description for the MIDIbox SID Control Surface? What I need for it? Quote Link to comment Share on other sites More sharing options...
DRÄPPEL Posted August 6, 2005 Report Share Posted August 6, 2005 http://www.ucapps.de/midibox_sid.html Quote Link to comment Share on other sites More sharing options...
Rio Posted August 6, 2005 Author Report Share Posted August 6, 2005 no, i need a description for the "control surface" (http://www.ucapps.de/midibox_sid_cs.html)? What are the things a need for? Quote Link to comment Share on other sites More sharing options...
raphael Posted August 6, 2005 Report Share Posted August 6, 2005 Just follow the link DRÄPPEL alredy gave you.And you willfind this (Step A IS the CS!!!): Control Unit (Step A)Additional parts and modules: a 2x20 LCD (or larger) a MBHP_DINX1 module - premade PCBs are not available for this small circuit, so you have to build it on a vectorboard. Alternatively you could use a DINX4 module. a rotary encoder (datawheel, endless pot)A detented encoder is recommented for precise data entry an improved PSU (ca. 500 mA) 6 buttons (or more if larger LCD is used) Costs: ca. 20-25 EUR for a backlit 2x20 LCD, 1..2 EUR for the rotary encoder, 1..6 EUR for all buttons (depends on the quality) Quote Link to comment Share on other sites More sharing options...
