VilladonEnt Posted September 12, 2005 Posted September 12, 2005 Hi Again,I wanted to purchase a Power Supply Today.Will a 9V 500ma wall plug be ok to power these?Midibox64--------------1 Character LCD2 Cores1 AIN3 DIN25 Potsabout 90 ButtonsI was going to buy from either DigiKey or Mouser.Thanks,Jason
raphael Posted September 12, 2005 Posted September 12, 2005 Depends on the LCD you use. Backlight can consume a lot. To be on the safe side look for a 800-1000mA supply.
VilladonEnt Posted September 12, 2005 Author Posted September 12, 2005 Hi,Here is a link for one. Would this be ok?http://www.mouser.com/index.cfm?&handler=data.listcategory&D=412-106084&terms=412-106084&Ntt=*412106084*&N=0&crc=true
VilladonEnt Posted September 12, 2005 Author Posted September 12, 2005 oh and yes it is a backlit display. :)Thanks!Jason
raphael Posted September 12, 2005 Posted September 12, 2005 Here is a link for one. Would this be ok?http://www.mouser.com/index.cfm?&handler=data.listcategory&D=412-106084&terms=412-106084&Ntt=*412106084*&N=0&crc=trueNo, this is only a 6V supply, you'll need 9V.412-109063 (9V/600mA) will do it if your backlight doesn't consume too much (take a look at the datasheet).412-109104 (9V/1A) will do it for shure.
VilladonEnt Posted September 12, 2005 Author Posted September 12, 2005 Raphel, Thanks for your quick reply! :DI am going to order the 412-109104 right now.I'm going to look for a male connector also, that can be mounted to my box. Do you know if a certain type of wire is required to connect to the core?Thanks for all your help!Jason
raphael Posted September 12, 2005 Posted September 12, 2005 Do you know if a certain type of wire is required to connect to the core?Every wire will do.
pay_c Posted September 13, 2005 Posted September 13, 2005 Errrr, I don´t know, but 500 mA are really ok for one LCD with backlight I think... :-[I mean, the max backlight´s are using is normally 300 mA (really veryveryvery bright) - normally you land between 100 and 200 mA for a "normal" lighting. The rest of your stuff (Cores, DIN, AIN etc) won´t use more than about 50 to 100 mA (max!), so 9 Volt, 500 mA power supply is ok, I think (I used more than one 500 mA supply here for the MB stuff I built - worked out well up to now).If you won´t use LEDs (which consume a bit more) you should be just fine with your power supply.*Please correct me if I´m wrong* ???
VilladonEnt Posted September 13, 2005 Author Posted September 13, 2005 Hi,Here is the Datasheets for the Adapter and the LCD I've already purchased.Adapter : http://www.mouser.com/catalog/specsheets/164155.pdfLCD : http://www.crystalfontz.com/products/2002a-color/CFAH2002ATMCJP.pdfHope I can still use this adapter ???I might add leds , I'm not sure yet.Thanks all,Jason
pwx Posted September 13, 2005 Posted September 13, 2005 Hi!....this should be ok... it´s 9VDC@1000mA ;Dand it´s also ok to add LED´s!greets,pwx
VilladonEnt Posted September 13, 2005 Author Posted September 13, 2005 Thanks! ;DI built the first core already, But before i build the 2nd core is there any modifications that will have to be done,or will i have to leave out parts on the 2nd core? I remember reading another thread where someone had to desolder someparts (Regulator? maybe - not sure) but that was a SID or a FM midibox setup not a MB64.Thanks guysJason.
VilladonEnt Posted September 13, 2005 Author Posted September 13, 2005 Oh... and , Im using SmashTV's PCB Kit.
raphael Posted September 13, 2005 Posted September 13, 2005 I built the first core already, But before i build the 2nd core is there any modifications that will have to be done,or will i have to leave out parts on the 2nd core?  I remember reading another thread where someone had to desolder someparts (Regulator? maybe - not sure) but that was a SID or a FM midibox setup not a MB64.No modifications needed. Just connect both cores J1 to the power supply. (The modifications you mentioned are necessary for a Multi-SID with optimized C64 supply.)Raphael
VilladonEnt Posted September 13, 2005 Author Posted September 13, 2005 Thanks Raphael.I know I have a lot of questions but I'm very new to electronics ;D Please bare with me.Thanks again everybody, for helping!Jason
