MEEF Posted November 25, 2005 Posted November 25, 2005 Hi, is it possible to buy premade core modules?
illogik Posted November 25, 2005 Posted November 25, 2005 no you actually have to do something yourself.... ;)you can buy kits though; you have to solder the modules yourself.this is a non commercial DoItYourself only project>> more fun, educational, you name it ...this forum will help you with problems you will encounter while building; just try and make sureyou read all the relevant info on the ucapps.de site, the Midibox WIKI pages and the forum before; because all the info you need is probably allready there!!good luck
MEEF Posted November 25, 2005 Author Posted November 25, 2005 thanks for the reply. I don't mind doing the work, its just that I don't know a great deal about electronics & thought that a premade one would be a good way to (physically) see whats going on before embarking on making my own. I just want to start off with a few pots & buttons & work up to bigger projects.
SMIDIRIN Posted November 26, 2005 Posted November 26, 2005 Get into it Meef.IT IS GOOD.many ideas become reality.build a core! get an lcd (even if later u remove it) . find or design a box/panel layout. you may get your panel cut for $ or do it yourself.it may be possible you could use just 1 DINX4 (and still get five buttons via one on the core)/ 1DOUTX4 / 1CORE.buying the pcb's will save you time and trouble.put it all together. by then you will have enough ideas for many midibox/mios creations for years of building. THORSTEN deserves thanks for that ! versatile platform for midi enthusiasts! PS. sliders give u the issue of having to cut slots( can be done with any method that works..) whereas round buttons and encoders or pots are just a simple hole.S
