SounDuke Posted December 7, 2005 Posted December 7, 2005 Hi everyone, I'm not sure, do the status display work in mackie control emulation? or the 2 status digits are only compatible with logic control? I connected them but Live 5 (mackie control emulation) displays random segments.
TK. Posted December 7, 2005 Posted December 7, 2005 Is this question related to this topic? http://www.midibox.org/forum/index.php?topic=5800.0As mentioned in this posting, there was a small error in the schematic (normaly very obvious, therefore propably nobody ever noticed this before ;-) --- did you take this into account?Best Regards, Thorsten.
SounDuke Posted December 7, 2005 Author Posted December 7, 2005 thanks for making it clear, but my problems are related to the green lines as I have no problem with the blue lines, digits 0-7 display the timecode with no problems. I'm quite sure I'm missing something obvious, but I checked all day long the connections and I found no errors. I have digit 8 and 9 which works (the select line is ok, the digits change according to the host timecode) except for the unreadable numbers (so it must be uncorrect data to the cathodes) and the same happens for the status digits. I managed to connect together the cathodes of the 4 led digits obviously following madly the segment map (each correspondent segment of each digit to a line connected to the appropriate dout).
SounDuke Posted December 8, 2005 Author Posted December 8, 2005 Hi Thorsten, the digits are now working, I tried solder and desolder until I found out that the connections are all upset in the schematic. In fact the dots worked when connected to D0 instead of D7 and I had to rearrange some segments too. Either the schematic presents mistakes with the default leddigits table or I'm dumb and made mistakes the first time I soldered the cathodes. Thanks for your support
TK. Posted December 8, 2005 Posted December 8, 2005 Hi,thats really strange, because based on the source code the schematic and the LC_LEDDIGITS_TABLE are matching.Could you please write down the exact pin mapping that you are using now, maybe this help me to find the inconsistency.Following format is sufficient (just edit it):J3:D7 -> Blue dotJ3:D6 -> Blue aJ3:D5 -> Blue bJ3:D4 -> Blue cJ3:D3 -> Blue dJ3:D2 -> Blue eJ3:D1 -> Blue fJ3:D0 -> Blue gJ4:D7 -> 3rd digitJ4:D6 -> 4th digitJ4:D5 -> 5th digitJ4:D4 -> 6th digitJ4:D3 -> 7th digitJ4:D2 -> 8th digitJ4:D1 -> 9th digitJ4:D0 -> 10th digitJ5:D7 -> Green dotJ5:D6 -> Green aJ5:D5 -> Green bJ5:D4 -> Green cJ5:D3 -> Green dJ5:D2 -> Green eJ5:D1 -> Green fJ5:D0 -> Green gJ6:D7 -> left status digitJ6:D6 -> right status digitJ6:D1 -> 1st digitJ6:D0 -> 2nd digitBest Regards, Thorsten.
Jidis Posted December 8, 2005 Posted December 8, 2005 SounDuke,Sorry for the stupid suggestion, but I'm guessing you did check the individual segments for the LED you're using beforehand didn't you? I've got duals here in green and red and the pinouts are totally f**d-up between the two.-George
SounDuke Posted December 9, 2005 Author Posted December 9, 2005 Hi jidis: it is not a stupid suggestion, it is a valid doubt ;) yes I did that, I'm using 0,8" led digits which I bought from bgmicro and have the same pinning (extracted from the same device I think). Since I'm only 20 I have little practice with electronics and it is possible that the schematic is right but my brain not, so it could be a false alarm :D.Tho: I'll write the pin mapping as soon as I can. Anyway, what does exactly the status digits indicate?
SounDuke Posted December 9, 2005 Author Posted December 9, 2005 J3:D0 -> Blue dotJ3:D1 -> Blue aJ3:D2 -> Blue bJ3:D3 -> Blue cJ3:D4 -> Blue dJ3:D5 -> Blue eJ3:D6 -> Blue fJ3:D7 -> Blue gJ4:D7 -> 3rd digitJ4:D6 -> 4th digitJ4:D5 -> 5th digitJ4:D4 -> 6th digitJ4:D3 -> 7th digitJ4:D2 -> 8th digitJ4:D1 -> 9th digitJ4:D0 -> 10th digitJ5:D0 -> Green dotJ5:D1 -> Green aJ5:D2 -> Green bJ5:D3 -> Green cJ5:D4 -> Green dJ5:D5 -> Green eJ5:D6 -> Green fJ5:D7 -> Green gJ6:D7 -> left status digitJ6:D6 -> right status digitJ6:D1 -> 1st digitJ6:D0 -> 2nd digitAs you can see, the pins of the cathodes are reversed while the select lines are ok. I hope this is not my mistake, but arranged this way the digits work
TK. Posted December 10, 2005 Posted December 10, 2005 Thank you for checking this!I still haven't an idea, why the segment pins are reversed, but I will doublecheck this with my own LED digit module soonBest Regards, Thorsten.
