I know this is an old thread but.. I just needed to comment. JMJ's lazer harp didnt work. I know from a very reputable source... my brother has worked with him on his Lyon concert (Houston/Lyon album).
"Uuh, jea really.." sounding like Beavis comin'  outta Butt"-Head..""But has anyone really heard any velocity on those redeavouass -pieces?!
Bye, Moebius
<not givin' any comments on those threads about IR sensors, just while ago>
Thats just the thing...  :) There is.  ..or it might be a filter effect.. what do I know.  :-/  But it was originally supposed to have like the D-beam.
Btw.. I am working on a design of a MidiBox D-beam and my concept will work! (dammit!)
Marc
Bye, Moebius
  • 1 year later...
  • 3 years later...
The link you have posted expired but i think the problem is the minimum output voltage that op-amp can handle. If an op-amp's negative supply is connected to ground, it cannot guarantee (it usually won't) to go down to 0 volts. For instance, a ua741 can give minimum 1.2V, a LM358N will give 0.2-0.3V. So, even if you do not use negative voltages, you should supply the op amp negative supply with a really negative supply.
The Sharp analog's can handle 30-40Hz of sudden changes, it responds continuous changes easily. The problem with them (i think) they give non-linear output wrt to distance. I was thinking today to interface it to MB, and i end up with the conclusion that an AD-Processor-DA chain should be used to calibrate and modify the output of it. I will design a simple circuit soon to handle it.
bump2.gif Um yeah, I am pretty sure d2k solved that problem or quit the project, after all he asked 4 years ago...
