vmidibox64 update : copy and paste + app settings
I made some quick changes to vmidibox64 (on your requests  ;D ):
- You can now copy and paste pot and button
   properties using CTRL-C, CTRL-V.
- CTRL-ALT-S saves the midi in port, midi out port,
 sysexsendspeed to   vmb64presets.ini
 these settings are loaded at startup and have the
 following structure in vmb64presets.ini :
[APPLICATIONPRESETS]
MIDIINPORT=1
MIDIOUTPORT=2
SYSEXSENDSPEED=120
Regards,
Serge
Hi Serge,
Thanks for making the changes. About the copy and paste: nice option :)
what about a make-settings-for-row option, thus that each knob of the row has the same controller (with min/max etc), but an increased midi channel for wach column?
it does save the midi in and out, indeed, but it doesn't initialize well: the buttons request sysex dump and send sysex are disabled on startup.
Good to hear there is progress in this program :)
TraiZor.
Hi Traizor,
: :-[   Okay I enabled the buttons at startup now.
: I will add it to the to-do list. What about another exotic shortcut for this trick ? (I wish to keep the basic interface as clean as possible)
Regards,
Serge
Hey,
I also like a clean interface, but shortcuts don't fit into a user friendly interface. Maybe a popupmenu with all the functions which are now shortcuts?
T
I don't like popup menus... but maybe I can make a simple shortcut :D that pops up a menu that gives you all advanced choices that are shortcuts now...
(I will keep all shortcuts in there as well... )
