serge Posted September 14, 2002 Posted September 14, 2002 Hi,I made some quick changes to vmidibox64 (on your requests ;D ): - You can now copy and paste pot and button properties using CTRL-C, CTRL-V.- CTRL-ALT-S saves the midi in port, midi out port, sysexsendspeed to vmb64presets.ini these settings are loaded at startup and have the following structure in vmb64presets.ini :[APPLICATIONPRESETS]MIDIINPORT=1MIDIOUTPORT=2SYSEXSENDSPEED=120Regards,Serge
TraiZor Posted September 15, 2002 Posted September 15, 2002 Hi Serge,Thanks for making the changes. About the copy and paste: nice option :) what about a make-settings-for-row option, thus that each knob of the row has the same controller (with min/max etc), but an increased midi channel for wach column?it does save the midi in and out, indeed, but it doesn't initialize well: the buttons request sysex dump and send sysex are disabled on startup.Good to hear there is progress in this program :)TraiZor.
serge Posted September 15, 2002 Author Posted September 15, 2002 Hi Traizor,the buttons request sysex dump and send sysex are disabled on startup. : :-[ Okay I enabled the buttons at startup now. what about a make-settings-for-row option, thus that each knob of the row has the same controller (with min/max etc), but an increased midi channel for wach column? : I will add it to the to-do list. What about another exotic shortcut for this trick ? (I wish to keep the basic interface as clean as possible) Regards,Serge
TraiZor Posted September 17, 2002 Posted September 17, 2002 Hey,I also like a clean interface, but shortcuts don't fit into a user friendly interface. Maybe a popupmenu with all the functions which are now shortcuts?T
serge Posted September 17, 2002 Author Posted September 17, 2002 I don't like popup menus... but maybe I can make a simple shortcut :D that pops up a menu that gives you all advanced choices that are shortcuts now... (I will keep all shortcuts in there as well... )
