adamwg Posted March 26, 2006 Posted March 26, 2006 Has anyone used a KL SN102 94V-0 LCD screen? i cant find a data sheet anywhere.I have wired it up the same as the wiring diagram but only the backlight comes on and mios studio shuts down. when i disconnect the lcd the core module acts as normal and mios studio does'nt shut down.Is this screen compatable with a midi box?
smashtv Posted March 26, 2006 Posted March 26, 2006 Hi Adamwg,Disconnect only the backlight, it is probably causing the shutdown by dragging down your power supply.Check the new wiki page about displays, there is a list of 44780 compatible LCD driver chips there that you can compare with your display to answer the compatibility question.BestSmashTV
LiFo Posted March 26, 2006 Posted March 26, 2006 i have just begun to paly with MIDIBOXand have a small problem i have a 4x20 LCDit works almost perfect but row 3 and 6 start printing on column 5so i was wondering if it could be that i maby have switch 2 wires or is it just my display that is strange ?
pay_c Posted March 26, 2006 Posted March 26, 2006 Row 3 & 6? ... ? ;DLook up in your main.asm. You´ll find a little table where you can adjust the offsets of all possible LCDs. High chances that there´s still the offsets for let´s say a 4x16 display in there.Greetz! :)
adamwg Posted March 26, 2006 Author Posted March 26, 2006 cheers smashi dont think the lcd i have is compatible.It would help if i could find some kind of data sheet for it. the pins seem to be straight forward they are numbered on the pcb.
pay_c Posted March 27, 2006 Posted March 27, 2006 There should be some manufacturer on there. Just email them and ask for it. In 70% of all cases, they can give you what you need or at least give you some hint.People here can also only look on google, you know...Greetz!
adamwg Posted March 27, 2006 Author Posted March 27, 2006 There is no makers name just a part code - KL SN102 94V-0
smashtv Posted March 27, 2006 Posted March 27, 2006 There is a thread in a car-mp3 forum with a non-standard pinout that looks promising:http://www.mp3car.biz/vbulletin/showthread.php?p=169814No idea if that will work or burst into flames.......Also know I found a thread in a different forum (in spanish!) that -looks like- one guy is telling another that he needs an inverter.....so yours might be an extended temp range model....complete explanation on extemp LCDs is in the wiki.BTW you can find 4x40, 4x20, and 4x16 displays from various different manufacturers.....with this same part number......making a datasheet search more like a waste of time.There are thousands of companies in China making character LCDs, cloning each other's designs furiously.BestSmash
stryd_one Posted March 28, 2006 Posted March 28, 2006 http://www.google.com.au/search?hl=en&q=SN102+LCD&meta=LOTS of hits :) Good luck mate.
LiFo Posted March 30, 2006 Posted March 30, 2006 from the doc's on the lcd function page i thought the lcd line arrangement was like this //sets the text cursor on LCD screen // 0x00-0x3f: first line /// 0x40-0x7f: second line // 0x80-0xbf: third line // 0xc0-0xff: fourth line after experimenting a little i have no clue what is going on here made a littel simple program to test where the display was displaying the test program void DIN_NotifyToggle(unsigned char pin, unsigned char pin_value) __wparam{ if(pin_value == 1) { switch(pin) { case 0 : val++; displayTest(val); break; } }return;}void displayTest(unsigned int val){ MIOS_LCD_Clear(); MIOS_LCD_CursorSet(0x00); MIOS_LCD_PrintCString("verdi"); MIOS_LCD_PrintBCD3(val); MIOS_LCD_CursorSet(val); MIOS_LCD_PrintCString("test string to g");return ;}the result from the test 16 dec line 340 dec line 246 dec line 280 dec line 4104 - 111 dec line 1120 - 128 dec line 1148 - 155 dec line 2164 - 172 dec line 2188 dec line 4212 - 219 dec line 1104 - 111 menas that "the test string to g" starts at column 1 on line xdont know if my display is a little strange or what but i think i can remember when i bought the display about 8 years ago there was somthing about that something had to be fliped, switched, reversed or negated to get it to work as an standard HD44780or it was just me that was drunk ?am using MIOS 1,8 and sdcc_skeleton_v1_0dand programming in Chope sombody has some idea what is going on here
stryd_one Posted March 31, 2006 Posted March 31, 2006 Find me the datasheet for your LCD and I'll tell you :)
LiFo Posted March 31, 2006 Posted March 31, 2006 have tryed many times an have not found any the only thing i have about it is on the pcb MDL-16465 andSN10294VO or 94V0on one of the chips there is a sticke MDLS1646S-01MDLS1645S-LV-it is a 4x16there is 4 chips on it3 x HD44100FS1 x HD44780A00
smashtv Posted March 31, 2006 Posted March 31, 2006 I just merged two of the LCD issues threads here, since you guys are both fighting these displays........One of you has a working pinout, one of you needs a pinout, etc..... Time to trade notes! ;DSmash
TK. Posted April 1, 2006 Posted April 1, 2006 LiFo: you are mixing decimal with hexadecimal numbers.According to the documentation: http://www.ucapps.de/mios_fun.html#MIOS_LCD_YAddressSet, a 4x20 display needs following offsets: MIOS_LCD_YAddressSet(0x00, 0x40, 0x14, 0x54);this function call can be inserted into the Init() hook.Thereafter you can access the display lines with: MIOS_LCD_CursorSet(0x00 + <column>); // for the first line MIOS_LCD_CursorSet(0x40 + <column>); // for the second line MIOS_LCD_CursorSet(0x80 + <column>); // for the third line MIOS_LCD_CursorSet(0xc0 + <column>); // for the fourth lineBest Regards, Thorsten.
LiFo Posted April 1, 2006 Posted April 1, 2006 Thorsten thanks for pointing me in the right direction i have just started to play with MIOS and had not seen the documentation under the MIOS_LCD_YAddressSet section just the under the MIOS_LCD_CursorSetMIOS_LCD_YAddressSet(0x00, 0x40, 0x10, 0x50);solved my problem as i have a 4x16 LCD regarding wiring i made the same wiring as on http://www.midibox.org/users/jim_henry/building_a_midibox_lcd_cable.pdfagain Thanks
adamwg Posted April 4, 2006 Author Posted April 4, 2006 Ive finaly got hold of a data sheet for the SN102 94V0.The pinning is standard. (the same as the wiring diagram on the lcd page)i'm not sure why i cound'nt get it to work though. hopefully i'll get my new pic's soon and i can get it working.If any one wants a copy of the data sheet i will email it to them.
adamwg Posted April 6, 2006 Author Posted April 6, 2006 I finally got the lcd to work.I got my pic's today and it all works fine.I think the lcd will not work unless a midi box application is loaded. I think this was probably why i could'nt get it to work before.
stryd_one Posted April 7, 2006 Posted April 7, 2006 Great news... The LCD should work with MIOS but no application loaded...Weird.... Hey, it works!
