Analog effects, was "Midifiying a sega genesis"
  • Replies 60
  • Created
  • Last Reply
Top Posters In This Topic
Good to see conversations plodding along nicely on these lines :)
..if i get round to it, i'll do a little test with pwm, led & a ldr ... n' let you know how well that solution works :) ..its a sweet way round a dac mind :)
That would be great!  There were positive indications in another thread for slow-moving and not very accurate CV like filter cutoff.  Would love to see your results.
At a fast enough rate, perhaps even a simple bitstream would do.  i.e. successively drop bits out of the stream for a lower CV.
  • 4 months later...
Just found this site selling tiny analogue FX boards.  Each board is 1 3/8" x 2", assembled, comes with pots, switches and jacks, and US$40-50. They're designed to mount inside guitars.  From the look of them, nothing you couldn't make up yourself from web schems and perf board, but still.
Nah I reckon because people interested in these are obviously not DIY-phobic and if they see the label on the chip they might google it and discover that they're
;D
C A Y O C O S T A
Here you can find schematics, wiring layouts, parts lists, chassis templates, photos and mp3 samples related to building your own classic recording studio equipment including:
  • Teletronix La-2a Compressor
  • Pultec EQP-1a Program Equalizer
  • Purple MC76 Limiter
  • Hansen 1975 Active Direct Box
  • Fender 5E3 Tweed Deluxe
  • Tube Direct Box
  • Redd.47 Microphone Preamlifier
All DIY gear was built over the last three years and is currently in use in my home studio.
I've added it to the WIKI links  ;D
I bet big money these are resultado's of prodigy-pro.com forum projects.
Besides it takes a big wallet to buy those in& out transformers that makes up for the vintage name
