SounDuke Posted May 4, 2006 Report Posted May 4, 2006 Is there anybody who is using lc with live? I can't understand if it is the DAW which doesn't send the info to turn on the bank/channel buttons leds or if I made a mistake in the wirings.
Silverfish Posted May 4, 2006 Report Posted May 4, 2006 Which DAW are you using? If it's Ableton Live, I know there's a way to turn on midi clip feedback... I just don't remember how....
Rowan Posted May 4, 2006 Report Posted May 4, 2006 Check this thread on how to get the MIDINoteFeedback working:http://www.midibox.org/forum/index.php?topic=6532.15Rowan
SounDuke Posted May 4, 2006 Author Report Posted May 4, 2006 thank you, I'm using live5, I only wanted to know if it is normal with no modding that live5 doesn't give feedback to the midibox to turn on those leds because the ones in my LC don't turn on.
Screaming_Rabbit Posted May 4, 2006 Report Posted May 4, 2006 I can't understand if it is the DAW which doesn't send the info to turn on the bank/channel buttons leds or if I made a mistake in the wirings.... use MIDIOX to check about your host is sending the appropriate informationGreets, Roger
SounDuke Posted May 8, 2006 Author Report Posted May 8, 2006 well, I managed to let them work (disabled on the I_O table ^^) but still I have problems with the center led of the ledrings and the overload of the meters (8ledrings and 8 ledmeters, each of them 11+1 leds). It seems that everything is ok, if I'm not wrong an aftertouch event should start the automatic procedure of filling the bit in the pattern by Mproc.inc. The problem is that the aftertouch event I see in the output of Live is something else because it is outputted even when there's no clipping in the track. To Ableton Live MBLC users, can you see the center led of the ledrings and the overload meter?
