Hello,
I'm wondering what program TK uses for drawing
the interconnection diagrams for the midibox projects?
I want to document my c drumseq project
and if possible I want the led/button wiring diagrams
to be consistent with the official MB projects..
Thank you,
Michaël
I think it's Eagle from http://www.cadsoft.de, I'm not sure though...
Hello, I know the schematics and pcbs are done in eagle,
but I want to draw something like this:
http://www.ucapps.de/midibox_seq/mbseq_din_v2.pdf
about my project, I'm building a simple drum sequencer
based on the clockbox example
specs:
-8 drumtracks with 32 steps
-each step has note on/off, accent on/off,(roll on/off)
-16 patterns (nr of patterns will be increased)
-patterns are stored on a bankstick
-loading/saving of patterns is possible when seq is running
user interface:
-20x2 lcd
-5 softbuttons + menu/ok button + encoder
-16 step buttons/leds
-8 dedicated buttons with play/pause, stop, menu shortcuts
status:
-seq is running with 16 steps with user interface
-currently there's only one loop length, note division for all tracks
-I'm able to run the seq with 32 steps but due to performance
issues the running led when seq is playing has to be disabled  :(
there's still a lot of work to do, I've written all the code in C to test the concept
without losing much time in code optimalisation
next week when my exams are done I will have more time to work on the code,
maybe some of you could help me with some C/ASM optimalisation
this is only my second C project so I expect there's a lot of room for improvement  ;D
here's a picture of my testsetup:
:o :D :D :D Great stuff :)
Heheheh I think it's funny, while I was waiting for bill, and bill was breaking his arm, you've got it done  ;D
A promising project! :)
I don't use the schematic tool of eagle, because the results are looking ugly and not always understandable for electronic newbies.
Instead I'm using xcircuit (a derivative of xfig) - not because it's the best, but because I'm familiar with this program since ca. 10 years and just love it :)
Thank you Thorsten,
I've just installed the precompiled windows version of Xcircuit,
could you please give me the xcircuit files of a din/dout connection diagrams
like the ones of MB_SEQ?
Michaël
I've uploaded the files to this location: http://www.ucapps.de/tmp/mbseqxc.zip
Thanks Thorsten,
I will post the diagrams together with my code when everything is finished...
don't expect too much from it , I just want to make a basic drumseq for my micromodular  :)
Looks like you've made some excellent progress!
If you need anyone to make up some PCB layouts or whatever then give me a shout.
Thanks Jaicen, I'm using a core module, a Dinx4 module and 3/4 of a Doutx4 module
so it's all standard pcbs...
I could use some good suggestions on the user interface and stuff like that,
will post more on that after my exams...
I like Geda.  See http://geda.seul.org/.  It's freeware, open source, and very capable.
I sure will try this program, I'm using eagle for drawing pcbs at school
and I don't like it that much  :)
for this project I will use Xcircuit so that the diagrams have the same look as the MB ones
Michaël
