tHe_IkkE Posted March 21, 2003 Posted March 21, 2003 Hi there,I'm thinking of building a pretty sick midi-baby with 24xMF 48xencoder 48xledring 96xbutton and some "normal controls".I thought this could be done with:3x18F running MIOSeach core running 8xMF 16xencoder 16xledring 32xbutton+led 2x 40x2 LCD ;DAnd one core for a graphical LCD and the transport controls etc.Is this at all possible?If I understand it right this coiuld be accoumplished with the use of the MIDI-link to link the cores togheter.I think I might have to use 2 MIDI llinks (or COM links) to the host PC in order to process the VU-meter data etc.I know it's only a lazy design picture but I'm actualy planning on building this baby.Thanks in advance guys!
d2k Posted March 21, 2003 Posted March 21, 2003 now that is beast!!and from what i've heard/read so far it seem perfectly doable - good luck!I think also u may even soon be able to have one main LCD that addresses all cores in the 'chain'...BestDan
tHe_IkkE Posted March 21, 2003 Author Posted March 21, 2003 I think also u may even soon be able to have one main LCD that addresses all cores in the 'chain'... I planning on using a graphical at the end, and 2 (or probably one initialy due to the costs) 2x40 LCD's on each core so you can see what you are doing on each channel. So you can use 1 encoder to select function (balance,AUX,bass,treble, etc) And one to select the value. I would then have something like this: [table][tr][td]PAN 1[/td][td]BASS2[/td][td]AUX3[/td][td]TREB4[/td][/tr][tr][td]L35[/td][td]+5db[/td][td]-20db[/td][td]+2.5db[/td][/tr][/table]Greetz tHe_IkkEP.S.: I forgot to put an LED-digit MTC display on the right
banneduser Posted March 21, 2003 Posted March 21, 2003 How I can to receive /whats hardware resourse is need/ a configuration with: • 16 motorfader+1 masterfader,• 8 encoder+8 LED rings, +1 encoder Jog/Shuttle for the transport control /btw. whether perhaps to use jog/shuttle encoder ALPS SRGP Series,10 pulses?/. • 5 button for Play/Stop/Record/FF/RW, • 64-128 assigned buttons+64-128 LED indications for this buttons?• 240x128 LCD BR Albert >
TK. Posted March 22, 2003 Posted March 22, 2003 How I can to receive /whats hardware resourse is need/ a configuration with: • 16 motorfader+1 masterfader,• 8 encoder+8 LED rings, +1 encoder Jog/Shuttle for the transport control /btw. whether perhaps to use jog/shuttle encoder ALPS SRGP Series,10 pulses?/. • 5 button for Play/Stop/Record/FF/RW, • 64-128 assigned buttons+64-128 LED indications for this buttons?• 240x128 LCD three core modules, some DINx and DOUTx modules and software skills (or somebody who helps you to customize this controller...)Best Regards, Thorsten.
Steven_C Posted March 24, 2003 Posted March 24, 2003 Now Now, stop giving Thorsten Ideas! or he will run out of space again! ::)
