leelinn Posted September 5, 2006 Posted September 5, 2006 HI,can u post the link of the .pdf mentioned above...V2.I canno't find it (of course it's my fault!!...sorry! :-[)lee
leelinn Posted September 5, 2006 Author Posted September 5, 2006 http://ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdfhttp://www.ucapps.de/mbhp_sid_old.htmlIn particular i have found this two source. The connections of SID & Core showed in the first link are different from the connections in the socond link.What of these 2 schemes do i use to complete (now that i have the time!!) my MidiBox SID V2?
Mr modnaR Posted September 5, 2006 Posted September 5, 2006 i'm pretty sure the optimised version is the one to go for.
Therezin Posted September 5, 2006 Posted September 5, 2006 That depends. If yu bought your boards from SmashTV or Mike, it should say on the board something like MBHP_CORE_V2 or MBHP_SID_V3. This indicates which versions of the connection boards you have, from which you can find out which diagram to follow. What do yours say?
leelinn Posted September 5, 2006 Author Posted September 5, 2006 I bought my board from a guy in Italy who made the PCB for me.ALL my SID and CORE board show : V2 (MBHP_SID V2; MBHP_CORE V2)So? where can i found the pdf for the interconnections i need?tnx
TK. Posted September 5, 2006 Posted September 5, 2006 The one which is showed at the http://www.ucapps.de/mbhp_sid_old.html page under the headline:MBHP_CORE -> MBHP_SID_V2 interconnectionsBest Regards, Thorsten.
leelinn Posted September 5, 2006 Author Posted September 5, 2006 tnx TK!ok that link works for one to one interconnections.But for multiply interconnections? I need to know the exact interconnectsion between 2 Core modules & 2 SID modules ;)lee
TK. Posted September 5, 2006 Posted September 5, 2006 There isn't a big difference, just duplicate the picture (both cores are controlling the SID modules independently)Thereafter you can do the MIDI link and power connections like explained in the optimized PSU schematicsBest Regards, Thorsten.
leelinn Posted September 6, 2006 Author Posted September 6, 2006 hi tk,tnx again!!! ;)my SIDs have both the 1Mhz osc.: i have to remove them a make this connection >> "SID clock to Core::J7:SO PIC Pin #17" ?
leelinn Posted September 6, 2006 Author Posted September 6, 2006 YesBest Regards, Thorsten. :'( :'( :'( i hoped you said "NO. it's not necessary. You may choose. If yr pcbs have mounted the oscillator you can keep it"......but if not...i'll remove the OSC.tnx again Thorsten ;) lee
TK. Posted September 7, 2006 Posted September 7, 2006 It's better without the external oscillator, see also http://www.midibox.org/forum/index.php?topic=5748.0Best Regards, Thorsten.
Altitude Posted September 7, 2006 Posted September 7, 2006 it's a simple fix, one wire to the one of the pins on the core (J7) to one of the legs from where the old osc was (look at the trace, it goes directly to the CLK pin, its pretty obvious)
