Hello everyone,
I'm having a hard time figureing out how to make metaevents work how I need them to. I would like to know how to send two cc's at once from an encoder or a button, and also how to send an nrpn stream. I have looked at all the examples I can find, but I just dont understand assembler. If someone could help me out with some code I would really appriciate it.
Thanks,
Luke
Hi Luke,
how about trying C if you don't understand assembler (I don't understand Assember, too ;D)?
There are examples on the bottom of the C-Page @uCApps.de, which describe what you want to do (send CC's, send NRPN).
Or is there any particular reason, why you want to do this in Assembler?
Regards,
Michael
Well i dont want to do anything too fancy, and I thought this is why TK has built in the meta events section. I just want all the normal functions of the mb64e with a couple of custom things.
it hasn't been clear to me, that you're trying to modify the mb64e, because in C there is also the possibilty to add an event-table...
sorry, have to pass then, don't know asm/mb64e enough :-\
I always liked teachers that made me figure stuff out on my own. I finally got it. Im sure its not the most elegant technique, but it works for what I need.
Thanks.
;;MidiChannel 9 & 10
MB64E_META_Handler_00
	;;Send first midi CC with fixed value
	movlw	0xB8		; send 0xb0 (Controller Header, channel 9)
	call	MIOS_MIDI_TxBufferPut
	movf	MIDI_EVNT1, W
	movlw	0x7F	; send 127
	;;Send second midi CC with incremental value
	movlw	0xB9		; send 0xb0 (Controller Header, channel 10)
	movf	MIDI_EVNT1, W
	movf	MIDI_EVNT_VALUE, W	; send enc/button value, stored in MIDI_EVNT_VALUE
goto	MIOS_MIDI_BeginStream	; end stream and exit
it's fine - as you can see, now you should have the possibility to send any MIDI event without asking for code snippets :)
  • 4 weeks later...
Would you be so kind and document your NEED and SOLUTION on the wiki?
Somebodey ought'a know where to link such page in WIKI.
