Machined-Pin IC Sockets
toneburst
Hi.
Machined-pin sockets should offer better reliability over the time (better contact with IC pins).
And You can (usually) solder these from both sides of the PCB, which is extremely useful feature for those DIYers making double-sided boards for home ecthing (You can use IC socket pins as vias between the sides).
(Uh, and I have also suggested using the extra space under the machined sockets for adding small axial capacitors between ICs power pins for bypass duties)
Moebius
... but also mention:
The "drilled" sockets hold the IC very strong. That's very good for mostly all purposes.
But if you often remove your ICs out of the sockets. It is F**king hard to get them out again.
I think, for digital applications the normal sockets are as good as the drilled ones. For audio applications I'll prefer the drilled IC sockets.
greets
Doc
