The III Man Posted December 5, 2006 Report Share Posted December 5, 2006 Hi,i have a faderfox and really like one feature. (This is with a view to building an ableton controller).In ableton to scroll up and down through scenes you can use one rotary encoder. However to select a channel you need to have an individual button for each one. The faderfox is clever in that when you turn the encoder it sends out a different midi note signal for each turn so you can map channels like this: 1 - g2 2 - g#2 3 - A2 etc etc.....This means that one roatry encoder can scroll through channels or for that matter any unlinked parameters you want saving on buttons and creating a lot greater ease of use.Is this possible with the Midibox64e or do the encoders only behave like endless pots?thanksIII Quote Link to comment Share on other sites More sharing options...
TK. Posted December 5, 2006 Report Share Posted December 5, 2006 Hi,there are 6 different modes, they can be assigned individually to the encoders, and each mode can send Notes. So, just select "Absolute Mode" for one of the encoders, and assign a note event.Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
The III Man Posted December 8, 2006 Author Report Share Posted December 8, 2006 Brilliant that'll save me so many buttons.thanks for your help Quote Link to comment Share on other sites More sharing options...
haris Posted October 22, 2008 Report Share Posted October 22, 2008 Now thats all cool ;)But is it possible to use 'step' encoders or potentiometers where the knob it 'locks' to a next step?These are used in CD players to skip to the next or previous track, sony has got them on their pro units.How are these called? And where can they be sourced in the UK? Quote Link to comment Share on other sites More sharing options...
arumblack Posted October 22, 2008 Report Share Posted October 22, 2008 Detented? Don't know of to many pots with more than a center detent, but there are many detented encoders with diferent numbers of detents. You could build a stepped attenuator for a detented pot, but I think the encoder is a better choice for this application. Quote Link to comment Share on other sites More sharing options...
haris Posted October 23, 2008 Report Share Posted October 23, 2008 Thanx for that... ;) Quote Link to comment Share on other sites More sharing options...
nebula Posted October 27, 2008 Report Share Posted October 27, 2008 Most of the encoders used by builders here are detented, that is to say they have 24 "click stops" per revolution. I am aware of the track selectors on the pro Sony players, and the common encoders around here would do a job like that perfectly.Usually MIDIboxers use the encoders on this Wiki page:http://www.midibox.org/dokuwiki/doku.php?id=encoders Quote Link to comment Share on other sites More sharing options...
