napierzaza Posted January 24, 2007 Posted January 24, 2007 Is there anything wrong with these LEDs? They're so cheap!http://cgi.ebay.ca/NEW-SUPER-BRIGHT-8000MCD-RED-5MM-LED-X-1000pcs_W0QQitemZ190060750727QQihZ009QQcategoryZ66952QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
doc Posted January 24, 2007 Posted January 24, 2007 Hm ... sure you'll have to ask on eBay if anything is wrong with this offer.For me it sounds good.But pay attention: These leds need a high current for full brightness (forwarding current 30mA). You probable kill the 74HC595 by driving these with 30mA. If you limit the current to about 15 - 20mA you're on the save side.greetsDoc
Jidis Posted January 24, 2007 Posted January 24, 2007 You may want to check that viewing angle with some people here (+/- 10degrees). Seems tight to me, but I'm usually going with diffused LEDs. I guess it depends on the box too.GeorgePS- Happy 500 Doc! ;)
seppoman Posted January 24, 2007 Posted January 24, 2007 +-10 viewing angle should be ok - this just means, the majority of light will be in that angle, but you could still notice if it is lit from further off-axis. But there are two problems with these extra bright LEDs in general:First, you need to give them enough current to be bright. With a large number of LEDs this means that you need a strong power supply and the 7805 will need a large heatsink. I don´t think it is cool if half of the power a unit needs goes into the LEDs. Second, high brightness and a small viewing angle mean that there´s an ultra small and ultra light dot seen from directly above that can even do damage to your eyes if watched for a longer time from short distance.Honestly, if you don´t need this ultra-bright stuff to show off to your friends or to read a book in a dark room, I´d always recommend low power LEDs. There are versions that need only 2 mA to work properly (i.e., use larger resistor values on DOUT boards) and are really bright enough. Price shouldn´t be a problem - you probably won´t need 1000 pieces anyway, and for e.g. 100 low power LEDs, everywhere else the price will be below the price of this auction incl postage.
napierzaza Posted January 24, 2007 Author Posted January 24, 2007 So can you get them at a fair price from Mouser than? If this is no good I'll move on, eBay doesn't seem very good for LEDs.
Jidis Posted January 24, 2007 Posted January 24, 2007 In the states, I've had really good dealings with this guy, but again, I just get regular diffused style lights right now:http://stores.ebay.com/West-Florida-ComponentsHe ships worldwide and is really helpful. There was a good assortment I got from him on green, yellow, red 3mm's a while back and I recently got a bag of 100 more reds. Indeed that eBay arrangement with the 100% item cost shipping is a PITA. They need to either get someone on there who sells assortments or who does a genuine "combined" shipping charge for a few different items. I'd guess that for lights, 3 or 4 different orders in one envelope or box probably wouldn't even change the real shipping cost, but they tend to give you a "price break" on multiples which comes out to crap.George
