Quite sane really :P :P :P
Well my SID 6581 gets hot.
All ten of them do :o :o  Hav'nt blown any up yet ;D
LO uses the 8580 or whatever it is and he reckons his does'nt get hot.
Glue a nice little heatsink on him.
Therefore Gilles, I reckon, it's down to you and me working some pretty hot riffs thru our 6581's that get's em all hot ;) ;)
Ian
TEN!??!! :o
Woah! Ok I saw the picture of the slaughtered C64´s but ten, that almost crazy!! (read: wish it was me...  ::) )
I can´t wait to build my first one (with a nice and cold 8580 btw...) :)
js
This is true my 8580 stays ice cold! even after +30mins of repeating a sequence. The 7805 on the core is another story tho! I think its about to melt a hole in my PCB!
Are you guys suppling 15v before the reg to the SID? I read somewhere it needs that to get a clean sound?!
Hey..
Lo, can I ask - what caps did you use for the filter part of the SID using the 8580s? The 6n8 ones as suggested? I tried these but had no joy...
Nice
Dan
@LO: But youre not putting the outcoming 12V of the SID directly to the 7805 of the core, do you? Or even the 15V (???)?
If you do: Try putting another 7809 before the 7805 (you dont need all those caps for the 7809 - the 7805 caps are enough).
Hope I could help you.
ummmm yeah 15v straight in to the 7805
thanks ill try the 7809
caps are 6n8 I think? ill double check tonite
Yes, 6n8 for the 8580
The descriped method (15 V -> 7809 -> 7805) is a good solution for converting the voltage without much heat
