Ringmodulation - what is it good for?
I've got a question concerning synthesizers in general:
What is ringmodulation good for?
I've tried several (soft-)synths and 2 ringmodulated oscs do always produce a really awful sound. IMHO you can't make music with this.
matthias
Using it on speech (second line some synth/saw/sine whatever) plus some delay is also a little nice effector. :)
(PS: I like delays so I put them ANYWHERE ;D ;D)
arrrghhhh!!! how dare you take the name of the Ring Modulator in vain!!
You are lucky I don't issue a fatwar or smite you or something...
So it's just useful for "FX" and stuff like that.
if you don't get what a ring modulator is good for then put it on EVERYTHING till you work out what it's the "killer tool at the right time" for....
because let's face it - the only way you are gonna work out what a Ring Modulator is good for, for you is to experiment!
I've used the CS80-V a lot, but everytime I switched on
the Rmod I hear this ..er...kind of "sweeping" sound.
perhaps the Rmod of my SID will sound better  ;)
Ringmod does this:
On Input A you have 200 Hz
On Input B you have 800 Hz
Ring mod builds the sum and the difference between A and B.
So at the output you will get 600 and 1000 Hz.
YOu'll get metalic and "unharmonic" sounds.
