mike Posted September 1, 2010 Posted September 1, 2010 (edited) Mike Thanks for the explanation! I've already ordered 6N138, now waiting for it. And, another question - R3 and R4, 220 Ohm both, why not to use just one, e.g. 440 Ohm? BTW, what current does MIDI current loop use, 20 mA or 10 mA? reboot good job! Sounds nice. I don't understand your question, R3 and R4 are not on the same pin (R3 on pin4 is supply and R4 on pin5 is signal). Consider that X3 is a Midi Thru port, is not necessary to play, it's for another Midi apparate that use the same played Midi Input. Current of midi loop I've never measured, but as i mentioned in last post midi signal is elaborate to ZERO Volt; important is frequency of signal, but for technical detail I suggest you a google search. If you make a search on the web, there are three similar project named: -Popp Meyer MIDImal (german) 1997 -Elektor 1997 -MistralXG (the best-with USB port and not only) 2009 .......... many thanks to Steve that helped and stimolate me!! P.S. I've tried CN17 and different 6NXXX and for my basic project are all good, the only difference it's speed of commutation - CN it's more slow, but we are speaking of microseconds so don't worry about this. Mike. Edited September 1, 2010 by mike
D_Garry Posted September 18, 2010 Posted September 18, 2010 Look, here's another similar project: http://www.joebrown.org.uk/wp/?p=3124
mike Posted September 19, 2010 Posted September 19, 2010 Look, here's another similar project: http://www.joebrown.org.uk/wp/?p=3124 Beatiful, but web page say that he's spent less of 30€ (25£). True?? To do my project for only pcb I spent 35€ each (and I've must ordered minimum of two pieces). So, if is there someone that have a web address to build a board more cheap it's appreciate.
philetaylor Posted September 19, 2010 Posted September 19, 2010 I am guessing for that price he made the PCB himself. A single-sided PCB is fairly easy to make yourself but you will need the equipment to do it. These will include copper clad board, some sort of etch-resist, and an etchant solution. You can get some quite good results but they won't have that professional look! Cheers Phil
mike Posted September 20, 2010 Posted September 20, 2010 Look, here's another similar project: http://www.joebrown.org.uk/wp/?p=3124 I've looked better project and I' think there a little error becaude pin 8 of wave connector is cabled in a connector for midi out with ground. I think must be connected with +5V to give a correct signal to an external midi device. Correct me if i'm wrong. I don't have a DB60XG so discussion it's only academic.
connectable Posted November 24, 2010 Posted November 24, 2010 Hi, I read with interest the comments above on stand-alone MIDI synth using Yamaha daughterboard. To answer a couple of comments: 1. Yes, it's a home-made PCB. These days I can make one in less than 30 minutes, once the schematic/track is laid down in Eagle. Naturally, I don't reflect the time spent in terms of price in my estimate for the total cost of my project. For those who haven't had a go yet, I urge you to try - pick a simple project and use one of those 'boil-in-a-bag' etch solutions to start with. Once you get hooked, then you can lash out and buy a bubbler tank etc. 2. The MIDI OUT connection on the Yamaha card (pin 8) is not used in my design, but I always tend to take potential future use into account. The last comment mentions that the connection should go via a resistor and the MIDI loop to a resistor tied to +5v and this is quite correct. I tend to sprinkle extra GND and power points on my PCB's these days, because I found that I tended to forget stuff and ended up having to solder GND connections directly to the foil on the PCB. The juxtaposition of a GND connection to the MIDI OUT pin is just sloppy on my part! I urge anyone considering hooking up a Yamaha board in a similar way to go ahead. I was so pleased with the result, I ordered another board and built a second unit. The sound of two units in parallel is absolutely awesome. Regards from Joe. Ref article: http://www.joebrown.org.uk/wp/?p=3124 Make a Yamaha Synth for less than £25.00
Shuriken Posted November 25, 2010 Posted November 25, 2010 I think it should be doable to make a Wavetable Module. Which would fit into the modular Midibox Family. If you would team this module up with a Core8 and Midibox64 firmware, it should be possible to send QS300 mode to the DBXG50 through a button for instance.
Shuriken Posted November 28, 2010 Posted November 28, 2010 (edited) I think it should be doable to make a Wavetable Module. Which would fit into the modular Midibox Family. If you would team this module up with a Core8 and Midibox64 firmware, it should be possible to send QS300 mode to the DBXG50 through a button for instance. I made a quick schematic which should fit the bill. JP6=5VDC JP7=+12VDC + -12VDC JP11=MIDI IN (TTL) Any comments are welcome. Edited November 28, 2010 by Shuriken
Milky Posted December 15, 2011 Posted December 15, 2011 oups!!! Hello Raoulblues Here is the original project and more project I bilt around DB50 & clone Projet 1 QS300 editor Project 2 name "Midinight" QS300 multi canal preset loader and more ( 6*128 QS300 sound on bankstick ) projet 3 Split keyboard with DB50 inside ( 6*128 QS300 sound on bankstick ) and many midi control projet 4 name " Milky " Five DB50 in one box with routuer 5*5 ( 37 * 128 = 4736 QS300 sound ) preset sender Please dont' send more about my project before the are finised ... Best regards
km2301 Posted February 5, 2012 Posted February 5, 2012 Hello, how do I get the QS sounds of XG-Gold in the bankstick ? Thank you
Milky Posted February 6, 2012 Posted February 6, 2012 Hello Km2301 XG gold manage QVB files with are difficult to read But in Xggold there is a QSbankloader. You can then transmit the le bank to the midi port and get it like a sysex in a program like midiox Sysex is in the form describe in DB 50 manual ( sorry for my english y am french ) Best regard Milky
km2301 Posted February 6, 2012 Posted February 6, 2012 Hello Milky, thank you for your Antwort.Ich have recreated this project( post of Raoulblues) and wanted to know the bank of the stick Midibox laden.Nur I do not like? (Sorry for my English I'm German and use a translator) Best regard KM2301
Milky Posted February 6, 2012 Posted February 6, 2012 Hello Translation is a little bit difficult to understand Raoulblues , few month ago , publish one of my earlier project with is a QS300 sound editor on midibox hardward. This is only a project , with actually many bug . the objet of the project was only to see if it possible to do it. If you are a good programmer , you can do it. Unfortunatibly, i have no time to complete a reel full running project. Only for the fun... Best regards
km2301 Posted February 6, 2012 Posted February 6, 2012 (edited) I understand this project is your work. A very good project. Unfortunately, I can be very bad you Programieren.kannst me the whole program not just send the hex file? Thank you How did you load the bank stick? Edited February 6, 2012 by km2301
sparx Posted April 2, 2012 Posted April 2, 2012 Have just hooked one of these up with a small interface board and a PSU, the sound is great! Where it goes from here and if it makes it to the MIDIbox family is another matter. Is anyone else looking at building something around this?
norbim1 Posted April 10, 2012 Posted April 10, 2012 I'm just finishing a box with the XG60 (NEC clone) based on the MistralXG project (with PIC18F2550, USB). My mods: - The audio output from the card is quite noisy, so I bypass the original DAC on the XG board. I connected the PCM data lines to a small board with PCM1754 DAC with very good result. - Audio input with opamp buffers to the XG60 - Modified Midi routing circuit - SW mod for the PIC (routing, flash for patches, mode selection, instrument selection etc.) Current state: HW is almost ready and working. SW is under dev.
mike Posted April 10, 2012 Posted April 10, 2012 Good ..... but it's possible see your project? I'm courious specially regarding your solution noise of nec card. Thanks, Mike I'm just finishing a box with the XG60 (NEC clone) based on the MistralXG project (with PIC18F2550, USB). My mods: - The audio output from the card is quite noisy, so I bypass the original DAC on the XG board. I connected the PCM data lines to a small board with PCM1754 DAC with very good result. - Audio input with opamp buffers to the XG60 - Modified Midi routing circuit - SW mod for the PIC (routing, flash for patches, mode selection, instrument selection etc.) Current state: HW is almost ready and working. SW is under dev.
norbim1 Posted April 11, 2012 Posted April 11, 2012 Hi Mike, Attached the schema of my DAC modification. DB60 Codec mod sch.pdf I'll take some photos also, and try to post tomorrow. Norbim
sparx Posted April 11, 2012 Posted April 11, 2012 Great work! I'm not getting noise from the output of an NEC card, its driving TL072 opamps and seems fine. As for the inputs, from what I've read, they take line level. There seems to be a lot these cards can do.....
Milky Posted April 13, 2012 Posted April 13, 2012 Hello Norbim Nice interface Unfortunatly my eyes are to old for so small soldering !! Do you thing it is possible to make a SPDIF interface from PCM signals ( BCK, data ,Lrck ) Milky
norbim1 Posted April 13, 2012 Posted April 13, 2012 Unfortunatly my eyes are to old for so small soldering !! I have my glasses, my head magnifier :) With some practice it's not so hard work. Here are the promised pics.
Shuriken Posted April 13, 2012 Posted April 13, 2012 I have my glasses, my head magnifier :) With some practice it's not so hard work. Here are the promised pics. Looks almost like a ready made module. Nice one. What case did you use for it?
norbim1 Posted April 13, 2012 Posted April 13, 2012 Looks almost like a ready made module. Nice one. What case did you use for it? HAMMOND 1455R1602 It's about 165*165*35 mm. Very nice case designed for 160 mm wide PCBs. I like it also and used this type earlier for a USB-Audio module.
norbim1 Posted April 13, 2012 Posted April 13, 2012 Do you thing it is possible to make a SPDIF interface from PCM signals ( BCK, data ,Lrck ) Hi Milky, I did a small search and found the DIT4096 chip from TI. I think it can do the job, it supports the DB PCM format via hardwired programming.
freddy Posted May 27, 2025 Posted May 27, 2025 On 4/14/2009 at 12:58 AM, stever said: This, or something like it, was what started me thinking about using my DB50XG for a project quite a few years ago... It was seeing the MIDI-Nator project that completed the puzzle and made me realise I could add a USB interface by using a suitable PIC device. Thanks for the compliment. I've made a few changes since the initial design was published and have a prototype board back that seems to work fine... I'm working on an enclosure at the moment... I hope it will be done in a month or so (not much spare time!). The results will be on my website (www.grapevyne.com/pic.projects)... I hope to include PCB info. Regards, Steve. Sorry to revive this long-dead thread after almost 13 years, I had MistralXG project on my to-do list for more than 10 years and I finally got to make the PCBs. Alas, meanwhile, Stever's website is down and Wayback Machine (https://web.archive.org/web/20210206041027/http://www.grapevyne.com/pic.projects/) only stores the primary site, not the linked images or other files. That means that I'm left with no firmware - anyone still has the binary HEX for PIC 18F2550 with (updated, based on the archived webpage contents, it should be v1.05)? Or even the sources, maybe? Thanks, freddy
