TK. Posted April 9, 2012 Author Posted April 9, 2012 V2.040 comes with an important bugfix: MIDIboxSID V2.040 ~~~~~~~~~~~~~~~~~ o fixed SysEx patch write issue which happened when patches were received with the common format (e.g. preset patches) [/code] Best Regards, Thorsten.
atom Posted July 4, 2012 Posted July 4, 2012 (edited) just downloaded the latest version and wanted to change the LCD line count but i get an error when building atom@elab /c/Users/atom/Downloads/midibox_sid_v2_040 $ gpasm.exe -v gpasm-0.13.5 beta atom@elab /c/Users/atom/Downloads/midibox_sid_v2_040 $ make rm -rf *.cod *.lst *.err rm -rf *.hex gpasm -p p18f4685 -I./src -I ./include/asm -I ./include/share -I ./modules/j5_ io -I ./modules/aout setup_6581.asm src/main.inc:25:Warning [209] Missing quote. src/main.inc:25:Error [103] syntax error ./include/asm\macros.h:188:Error [113] Symbol not previously defined (MBSID_VERS ION_STR). make: *** [setup_6581.hex] Error 1 atom@elab /c/Users/atom/Downloads/midibox_sid_v2_040 Version issues ? @update nevermind had to download the latest gputils from sf.net the WIKI link points to the 13.5 version and thus the error appears. Edited July 4, 2012 by atom
TK. Posted September 8, 2012 Author Posted September 8, 2012 MIDIbox SID V2.041 is available now. From the ChangeLog: MIDIboxSID V2.041 ~~~~~~~~~~~~~~~~~ o corrected sysex handling for MIOS Studio SysEx Librarian [/code] The SysEx Librarian is part of MIOS Studio 2.3.0 Best Regards, Thorsten.
TK. Posted December 30, 2012 Author Posted December 30, 2012 MIDIbox SID V2.042 is available http://www.ucapps.de/mios_download.html'>now From the ChangeLog: MIDIboxSID V2.042 ~~~~~~~~~~~~~~~~~ o new SysEx commands to support the Lemur Editor o MIDI Clock is now optionally sent with the "Out" option of the Ensemble Clk page. o default encoder mode is "DETENTED3" now, since it works better for most encoders available on the market o swapped behaviour of ENC speed control: encoder now at fast speed if SHIFT button is pressed So: the update is especially recommended for users of the upcoming http://midibox.org/forums/topic/17536-midibox-sid-v2-lemur-editor/'>Lemur Editor, and for users who noticed problems with their menu encoder. Best Regards, Thorsten.
Johey Posted December 30, 2012 Posted December 30, 2012 (edited) Indeed it does! Thank you very much! Hope Wilba did not send me a new encoder. This also helped my flawky cutoff encoder on my MB6582. Supergreat! Edited December 31, 2012 by Johey
TK. Posted December 31, 2012 Author Posted December 31, 2012 Cool! :sorcerer: Best Regards, Thorsten.
TK. Posted April 20, 2013 Author Posted April 20, 2013 A new version is available: MIDIboxSID V2.043 ~~~~~~~~~~~~~~~~~ o fixed NRPN handling for Multi patches o implemented CCs for Bassline/Drum/Multi Engine See doc/mbsidv2_cc_chart.txt for available CCs o display updated when the patch name has been changed from external Best Regards, Thorsten.
Jesy_par Posted August 11, 2014 Posted August 11, 2014 Just wondering, is there was a way to enter the special instrument modes (multi, bassline, drum) without the use of a "shift" button? I just finished my V1, but V2 is working great; the lead engine is so deep! I wanted to try out the different modes, but don't have all the buttons hooked up for V2. Thanks
TK. Posted August 14, 2014 Author Posted August 14, 2014 Hi, you could switch between the modes with the Ctrlr based editor: It makes sense to explore the capabilities of MBSID with this editor anyhow before you start editing with the CS :) Best Regards, Thorsten.
TK. Posted December 19, 2014 Author Posted December 19, 2014 MIDIbox SID V2.044 has been released Aside from the encoder handler improvements (which require a MIOS V1.9h update!), we also got a nice christmas present from Lis0r. She improved the OSC Detune function by a new "SuperSaw" mode which is based on the research from this paper: http://www.nada.kth.se/utbildning/grukth/exjobb/rapportlistor/2010/rapporter10/szabo_adam_10131.pdf Your SIDs never played so fat sounds before!!! :hyper: Changelog: MIDIboxSID V2.044 ~~~~~~~~~~~~~~~~~ o This version got an improved rotary encoder handling. Please update to MIOS V1.9h before uploading the application, otherwise the improvements won't be effective. o swapped behaviour of ENC speed control again, so that encoders are at fast speed by default, and slow if SHIFT button pressed. This behaviour can now be alternated in your setup_*.asm file by changing the DEFAULT_SHIFT_SPEED_CONTROL_MODE option o implemented special encoder testmode which can be enabled with DEFAULT_TESTMODE_ENC_SPEED in the setup_*.asm file o envelopes are now released properly when a note is played via the SysEx editor (or with the PLAY button) o added new "SuperSaw" detune mode which has been created by Lis0r. In distance to the normal (legacy) mode, results are much better especially on higher detune values! The detune mode (DtM) can be selected in the OSC page for lead engine patches, and in the O23 page for bassline patches. For your own comfort here some concrete update instructions for the complete update (the last MIOS8 update happened 5 years ago, so that some of you might have forgotten what needs to be done ;-) connect your MIDIbox SID to a MIDI interface (bidirectional IN/OUT connection required) open MIOS Studio, select the MIDI IN/OUT port there Query should result into "Application is up&running" Now upload the mios_v1_9h/pic18f4685/midi/mios8_v1_9h_pic18f4685.hex file of the mios_v1_9h release package Thereafter upload a matching setup_*.hex file of the midibox_sid_v2_044 release package The MIOS V1.9h update is only required for the master core (because slave cores don't use the encoder handler) If a MB6582 or similar MIDIbox SID V2 with multiple PICs should be updated (so: no sammichSID for example), clone the application to the remaining PICs by pressing&holding the MENU button while the version number is displayed on the LCD. Best Regards, Thorsten.
XC3N Posted December 22, 2014 Posted December 22, 2014 (edited) Awesome! Thanks! Enjoy a beer! ;) My encoder was behaving perfectly in 1.9g but in 1.9h, not so much :s I will definitely invert the shift behavior as it seems backwards for the way I use it,,, I'll try the test mode.... 2nd edit: don't frget to run cmd as admin, dummy ;) edit: so I'm trying to compile the ASM file with test mode enabled. I followed the toolchain tutorial in the wiki, set path, modified makefile to only compile sammichSID but when I do MAKE, I get a bunch of errors: [...] ./include/asm\macros.h:61:Error[113] Symbol not previously defined (GIE) ./include/asm\macros.h:65:Error[113] Symbol not previously defined (INTCON) ./include/asm\macros.h:65:Error[113] Symbol not previously defined (INTCON) ./include/asm\macros.h:65:Error[113] Symbol not previously defined (GIE) ./src\sidplay.inc:438:Error[113] Symbol not previously defined (STATUS) ./src\sidplay.inc:438:Error[113] Symbol not previously defined (STATUS) ./src\sidplay.inc:438:Error[113] Symbol not previously defined © ./src\sidplay.inc:439:Error[113] Symbol not previously defined (BANKED) [...] This is but a small extract of a command window overflowing with errors Any clue what is wrong? I have no prior compiling experience so it might be something stupid. thanks Edited December 22, 2014 by XC3N
missingsense Posted January 20, 2015 Posted January 20, 2015 Really liking the supersaw for 303 lines By the way, I'm getting a lot of accidental double button presses on my sammichSID, it's driving me nuts.. could that be solveable in software?
jjonas Posted January 20, 2015 Posted January 20, 2015 I had the same problem a few years ago, check out this thread: 1
missingsense Posted January 21, 2015 Posted January 21, 2015 I had the same problem a few years ago, check out this thread: many thanks, I'll try this out tonight
missingsense Posted January 21, 2015 Posted January 21, 2015 Had to raise it to 50ms but now it's perfect, thanks!
